Results 1 to 3 of 3
Thread: S2000 Fuel Lines
    Spanner Monkey a.south1234's Avatar
    Nov 2011
    Maldon, Essex
    29
    244
    16
    S2000 Fuel Lines
    I have managed to fit the standard S2000 fuel pump/sender into my fuel tank, the next issue is to run a fuel line under the car. I was planning on using 8mm Copper line under the car but i do not know where to get any adapters that convert the s2000 fuel pump to a standard push on hose. The link below shows the type of connectors on the fuel pump. I need to convert this to a push on rubber hose.
    http://www.ebay.com/itm/Honda-S2000-...-/231145825239
    Any suggestions are greatfully recieved.
    Thanks,
    Aaron
    Nov 2011
    Maldon, Essex
    29
    244
    16
    Re: S2000 Fuel Lines
    Ended up using these on the inlet and return they are liek the factory fitting ones.
    http://www.summitracing.com/int/part...-213/overview/
    Jul 2010
    South Wales
    32
    4,840
    222
    Quote Originally Posted by a.south1234 View Post
    any photos of the car/fuel tank sounds like a great budget option by keeping the honda fuel pump and in ctank filter too.
