Re: The guide to fitting a zetec for RWD?
Just look at my website its dedicated to fitting the ZETEC to the Mk 1/2 Escort. Anything I have missed can soon be added. Don't bother with the 1.6 ZETEC either becuase even after spending £1500 on tuning it will still have less power than a standard 2 lt or RS1800 spec 1.8.
I was just thinking for standard just to get the set up in there and working and insurance friendly and most importantly reliable!...not for big power, as obviously there will be those like me who are younger and cant really afford big engines with mods etc. Thanks for the link, will check it out now
Engine Back For Handling.
Parts.......... Dunnel..........
Sump, pick-up pipe, clutch, flywheel, engine mounts, inlet manifold
Parts ...........Raceline...........
water rail and thermostat housing
Parts.......... Steve Greenald.......
Carbs/ throttle bodies, ECU + loom, coil-pack, Mapping
Parts.......... Rally Design...........
Exhaust, Kenlowe, Oil Cooler, Air Filters. WCXM
Parts ......... S & C Electrical .........
Starter and Alternator.
Parts........ Local Motor factors........
Bits of water hose,etc. and the waterpump .
Parts........... Salvage yard.........
The Engine and gear box (for a type9)
Parts......... Escort Tec, Mr_Hoarder, 2quick4u,
RS2000 bell housing.
Parts.........Reco-Prop..........
Propshaft
Fabrication..........Retromotorsport Ltd..........
Bulkhead and gearbox tunnel (under £500)
Gary,
And dosnt that look so nice in there
A conversion worth every penny !
Thats a nic engine looks well in there
i'm now having a pause with my project....
upper bulkhead lip shortened and gearbox tunnel raised, battery goes into trunk.
rs2000 bellhousing + type9 + mondeo 1.8 flywheel and clutch and 1-piece hd prop.
intake manifold from Burton.
45 webers
megajolt lite ignition
BMW alloy radiator
all other parts homemade...
Cheers,
Tepi
