On the above are they just noral spherical bearings??? Or are they some sort of super dooper all sinlging all dancing wotsits??
Yea some info in this will be apreciated as im busy rebuilding my front struts aswell. Also RMOz posted some pics of his adjustable front struts using standard springholders - and I cant seem to find the Thread
There just spherical bearings. The higher load rating the better, but more expensive.
Im in the middle of installing these, not adjustable though..............Yea some info in this will be apreciated as im busy rebuilding my front struts aswell. Also RMOz posted some pics of his adjustable front struts using standard springholders - and I cant seem to find the Thread
Which Ive made up from.............
Aurora site lists race and others...........
On the surface, the race ones look like the have stainless outers as to steel for other.
I bought a couple o sets of these
so if they bugger up, Ill change em.
More info.............
http://forum.osella.com.au/topic.asp?TOPIC_ID=706
Attached could be useful for calculating tyre camber lean angle
Thanks Roger, I meant the spring hight was adjustable - the pics where of standard coil spring holders that had been modified
Aurora eh, cha ching!!
Fooking good quality tho......Have used them before
glenn22481,
This mob have both, closer to u as well?!
http://www.essexparts.com/index.shtml
Bit of gear available, generally as well..........
http://www.essexparts.com/CatalogPDF...nds_Sphere.pdf
Bearings
Some types, images, of top mounts....
Std ones modified.
Aftermarket...
A fair amount of car lowering can be had with mount above inner wing, without compromise to suspension travel
Some adaptors will be needed to fit Spericals, so they swivel, without bind.
I got some GE25ES-2RS from Midland Bearings (www.midlandbearing.com) only £5 a pair inc postage
