standard pistons
anyone know the diameter of them?
also, any idea of with a bit of machining, they will fit zetec rods?
cheers, Eirian
Re: standard pistons
Standard bore 90.820
1st over 91.070
2nd over 91.32
Pin dia 23.997
Compression heights available between 35mm and 40.5mm
Bore clearence 3.5 - 4 thou
Hope that helps
thanks,
