Results 1 to 15 of 15
Thread: black top zetec water pump
    Nov 2004
    uk
    33
    dose the black top mondeo zetec water pump need changing
    for a mk2 escort dose it go in the right way
    Jul 2004
    Reading
    1,275
    Re: black top zetec water pump
    As far as I know it goes the wrong way, finda 1.8 ltr engine and get the pump. While you are at it get the lighter 1.8 flywheel.
    Pit Crew Decade Plus User TepiTheFinn's Avatar
    Jan 2003
    Finland
    1,226
    this is pic of my 2.0 blacktop waterpump, and i think it's same for 1.8 blacktop.
    but with older silvertop, where pump mounting is totally different, you can change direction of rotation just using 1.8 pump.
    Cheers,
    Tepi
    Nov 2004
    uk
    33
    but what will i do with the black top water pump for my mk2 escort is going in the right direction?
    i have is laided out the way phoenix escorts have it done but im not sure about the water pump im still using the smooth pulley?
    Jan 2005
    northampton
    I am also interested in what to do, I need to get the water pump spinning in the opposite direction for my installation. Is there another pump out there that can be used?
    Aldershot
    4,538
    Give Retro Ford a call and see what he thinks.
    Aug 2005
    Hey guys, I wonder if you can help me I am wondering the same thing as some of you.
    What waterpump to use to change the rotation from a stock 2L zetec to work with just Alternator, waterpump and crank configuration.
    The problem is there are no 1.8 escorts in Canada so getting one is rather difficult.
    Could someone find the part number for this pump? And post it up, It would realy help.
    Jan 2003
    Finland
    1,226
    microcat gave me these numbers
    Spanner Monkey Tazzie's Avatar
    Jan 2005
    Flevoland- the Netherlands
    58
    Quote Originally Posted by ImFromCanada
    Depends on what kind of zetec engine you are using.
    Is it a silvertop zetec you can try to get a hold of a waterpump from a european escort 1.6 or 1.8 zetec.
    Is it a blacktop zetec you are out of luck as they all rotate in the same direction
    regards Tazzie
    Jan 2003
    Finland
    1,226
    does anyone have close-up pics of Focus RS waterpump and pulley? part numbers are different, just wondering is it same direction of rotation...
    Jan 2003
    Finland
    1,226
    just removed pump from my year 2000 blacktop.
    here are the piccies...
    was thinking to search different car makes and models to get reverse direction blades.
    pinto has quite same size wheel with straight blades, could work also.
    my friend is a cnc machinist, think i better show it for him too, maybe he is interested to fabricate one for me.
    Spanner Monkey Phil01825's Avatar
    Dec 2005
    East Sussex
    335
    With Retro Fords kit there is no need apparently to change the water pump as an additional idler is fitted above the water pump pulley thus maintaining the original direction of rotation. Have a chat with Dave College at Retro Ford as he is extremely helpful
    Jan 2003
    Finland
    1,226
    yes, idler is the easiest way to make it work. but when you want things to look simple and more period seventies you need reverse blades.
    Aldershot
    4,538
    You could do away with the water pump and run an electric water pump instead. I believe David White did this to his zetec.
    Nov 2004
    Sunny Essex
    4,831
    100
    Quote Originally Posted by RChambers
    Yep a Davies Craig water pump is a really good way , but I believe that if you speak to Dunnell or Raceline they will sell a replacement pump or reversed impellor.
    They are doing hundreds of these conversions so I cant think that they wouldn't have an off the shelf cure by now
