Re: Escort bits for sale MK2 RS2000 & performance bits
Pm me as im after the sump pick up bellhousing and the good pair of Mi16 calipers with a price for the 3
PM me if a rear bumper is available.Cheers Justin
YOU HAVE P.M
Anglia360: Sorry no rear bumpers, the shell was a complete right-off so was stripped.
you have another pm m8
Frank
Right My Mk1 Escort bits for Sale. I haven't got pics for all of these yet. Some bits are still on my car so if you want them it might take me a while to take them off.
Stage 3 Crossflow cylinder head £300.00 pic from before work. This has been cleaned up and decoked, valves ground in, new valve stem seals, double valve springs, unused since rebuild, ready to fit.
Crossflow Sport inlet manifold for twin choke weber £35.00
MK1 escort original leaf springs (pair) £20
Diff. can't remember what the ratio is! lol will check on that one.
MK1 original front suspension with drum brakes. £35
MK1 original anti roll bar £10
MK1 Escort Auto box, good condition £30.00
MK1 Escort auto 2 piece prop shaft. has 24 spline end. As far as I can tell its the same as a 2 piece RS2000 one. £35
Beige interior includes front and rear seats and door cards, rear cards other beige bits. 1cm tear in each front seat, small burn on rear seat due to leaving lead lamp on seat too long while fitting new front seat belts! Other than those bits. in very good condition. £60.00
Alloy rocker cover, the one with ribs going from front to back. with cap breather hole and correct low profile gasket, £35.00 might have the bolts for this too.
MK2 RS2000 alloy bellhousing. Lovely and clean, all threads fine. comes with original rubber bungs. fork missing though. £100
Weber DCOE twin 40's Refurbished with new weber kits. Thought to be jetted for a 1600 crossflow comes with incomplete official webber linkage. unused since rebuild £300.00
Ashley exhaust system for 1300 crossflow. 4-1 manifold, twin box system and 3" tail pipe. Sounds the nuts! Has had some mounts changed and axle tube relocated due to originally being out of shape £120.00 on car
Twin 40's inlet manifold painted gold with fitting kit £45.00
Lumenition £80 on car
Magnecor 8.5mm HT leads not side exit cap. £30 on car
1600 crossflow flywheel. has been completely cleaned, re-faced and fitted with a brandnew pre-engaged ringgear. Not used converted by Specialised engines. £120
Brand new clutch kit, this is the correct kit for fitting a 1600 crossflow flywheel to a Type 9 box. £60
1300 crossflow engine. Built by Specialised engines. Great condition and brilliant runner. Comes with standard unleaded head. PM for more details. £150 in car
Original MK1 escort steel wheels and hub caps. set of 5. some with almost new tyres. £50
Mk1 escort 4 door drivers side rear quarter panel. original ford. unused. £40
RS Alloy gearbox mounts £10.00
Only used to hold my gearbox up while I was making my own mounts. RS ones don't fit an auto shell.
New rear inertia seat belts from Halfords £40
I will also have for sale once Gary has done my car.
2.8i Bilstein front struts, rebuilt by LEDA and converted to 2.25 inch springs, braced, £240.00
Single leaf rear springs bought from West Wales Rally Spares, including bushes. £80.00 These are very stiff, and will require the use of lowering blocks or ce-cambering. I have used 6.5" Revolutions on the back of my Mk1 with no rubbing using these. No Panhard rod either.
5*6.5"Revolution wheels and tyres for 4 £100.00
Original rear axle £50
Apologies for big pics, I don't know how to shrink them.
I hope I have got this lot right, contact me with any questions.
might have more bits but can't think after that lot!
Wow you guys are like vultures!
No need to keep writing "you have a PM" don't want the post getting clogged up.
its first come first served so get in contact.
I know you said not to P.M. but you have P.M.
Parts sold so far:
RS2000 K&N Airfilter
Mk2 RS2000 column
Mk2 RS2000 alloy bellhousing with correct fork and rubber bungs
Mk2 RS2000 alloy sump and pick up + dipstick
Standard Rack
other standard rack
Loads of other parts still available please see above posts
Also now have for sale a pair of 2.8i special halfshafts.
BTTT
Still stuff that needs selling.
PM me with sensible offers.
You still got the mk2 anti-tramp kit for sale?
It is not a kit just the bars, and they are still for sale.
BTT
This stuff is all going on E-bay over the next couple of days. make me an offer before it does.
Nearly all items now on E-bay
what ratio is the diff and how much
just want to get hold of one for a spare
cheers
I can't remember I will check for you tomorrow.
Still some bits for sale. They are gradually making there way onto E-bay so be quick.
2.8i Bilsteins converted to 2 1/4 £200
M16 calipers chip out of one. £25
MK2 RS2000 clocks £40
M16 Calipers undamaged £40
MK2 RS2000 TCA's £5
RS2000 Exhaust manifold £20
MK2 RS2000 2 piece prop £40
MK2 RS2000 4 speed gearbox £60
MK2 RS2000 steering wheel £25
Mk2 RS2000 wheels and tyres some kurbing £100
MK2 crossmember converted to fit 100E £50
Mk2 RS2000 Engine minus all alloy bits Standard as far as I can tell, head off for inspection. £150
MK2 RS2000 alloy bellhousing. Lovely and clean, all threads fine. comes with one rubber bung. fork from sierra. £100
Lumenition £80
Single leaf rear springs bought from West Wales Rally Spares, including bushes. £80.00 These are very stiff, and will require the use of lowering blocks or de-cambering. I have used 6.5" Revolutions on the back of my Mk1 with no rubbing using these. No Panhard rod either.
Prices can be reasonably negotiated.
James
have you got any pics of the wheels??
