Page 3 of 3 FirstFirst 1 2 3
Results 81 to 98 of 98
Thread: Capri Mk 3 project with 550bhp V10 engine
  1. #81
    Jan 2012
    Aberdeenshire
    417
    Re: Capri Mk 3 project with 550bhp V10 engine
    Love this car and admire your skill set. Can't wait to see it done
  2. #82
    Mechanic DANGERDAVE80's Avatar
    Jul 2008
    Edinburgh, United Kingdom, United Kingdom
    806
  3. #83
    Jul 2015
    Essex UK
    Finished the moulds and made the panels for the Tub, weight of all 4 panels (roof, 2 sides and rear panel) is under 20kgs and much stiffer than the steel ones.
  4. #84
    Apr 2017
    Essex
    790
    100
    Very impressive !
  5. #85
    May 2010
    london
    1,139
    Quote Originally Posted by andygtt View Post
    wow....cheers mark
  6. #86
    Apr 2013
    About
    257
    12
    Great work
  7. #87
    Jul 2015
    Essex UK
    After what seems like an endless task of design and fabrication I finally had enough of the front suspension to mocking up the front wheels... I changed the design significantly mid fabrication by deciding to use BMW stud instead of the original ford... this means new wheels, new hubs, new wheel bearing, slightly different offsets and thus changes to the geo to accommodate
    I also finished machining the brake bells and adapters (as I had already had these made prior to the changes).
    The reason for the design change? basically I now have a huge range of suitable wheel design and sizes with the offsets i now run, and the wheels are available off the shelf.... Also the bearings, hubs etc all are beefier than before and i don't have to machine them myself, this is actually a significant advantage as I intend to keep this car long term.
    Another ramification is im going to need to change some of the front chassis as the main brace diagonal is potentially going to touch the tyre with 2 inches of bump in a counter steering position... basically when the rear end steps out and I have to counter steer to catch it lol
    Anyhow it was all worth it as its now exactly what I want with no compromises at all.. I can now start making the front wheel arches, like the rear my starting point is the X pack kit, however I have to widen it and move the wheel significantly higher in the arch, Ive also extended the wheelbase a little.
    Brakes are 370mm discs with 8 pots, these run 2 brake pads so double bite of a standard single pad setup.
    Wheels are now 10x19 front so I can run 260/30/19 tyres all round, I'm going to run electric power steering.
  8. #88
    May 2004
    Norn Iron
    1,141
    Serious amount of work there, but it makes a lot of sense to make subsequent parts more readily available.
  9. #89
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    I love the engineering in this. Keep up the good work.
    Are you making those carbon fibre panels yourself?
  10. #90
    3,237
    'Take no Sh*t stoppers' - like it!
  11. #91
    Jul 2015
    Essex UK
    yes I’m making everything myself, including the moulds and carbon bodywork... lots of work, but I enjoy it.
  12. #92
    Jan 2012
    Aberdeenshire
    417
    Impressive, every part of this build is stunning and quality. Looking forward to seeing her complete
  13. #93
    Oct 2011
    Plymouth, United Kingdom
    11
    Nice
  14. #94
    Jul 2010
    Herts
    426
    what do you have planned axle wise ?
  15. #95
    Jul 2015
    Essex UK
    rear suspension is independant, so i can use any Diff I want... current plan is to use a BMW one, but depends on gearing and cost new
  16. #96
    Jan 2011
    montgomeryshire
    126
    Any update on this project?
  17. #97
    Jul 2015
    Essex UK
    No significant updates I'm afraid as been working on my other project the noble... unfortunately I've had massive spec creap on the noble so its taking more time and money I had planned
  18. #98
    Jan 2012
    Aberdeenshire
    417
    Glad it is still on the radar as it’s a phenomenal build and will be a stoner when it’s done
