Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 41 to 80 of 199
Thread: Zetec Install
  1. #41
    Jan 2005
    lincs
    268
    Re: Zetec Install - Water temp sensor
    changed my cambelt when the engine was out just for safetys sake! cost £65 for the kit but its worth it imo
  2. #42
    Aldershot
    4,538
    Same here but I work at Halfords so it was a bit cheaper
  3. #43
    Jul 2004
    Reading
    1,275
    I'm doing my belt too, fitting the 130 ps cams while i am at it. Then I have 50k+ plus before i need to worry!!! With regular oil changes it will last for ever!!
  4. #44
    Aldershot
    4,538
    I think the cambelt is rated to 80,000 miles but I wouldn't leave it quite that long! I'll be happy if my engine lasts half that . Still if I can get a few years out of it then I've got my moneys worth. Only a few hundred to replace it anyway
    Richard
  5. #45
    I love to crap Decade Plus User PercyBigun's Avatar
    Jul 2002
    Cambs UK
    how can you shorten the spacing between the motorbike TB's to line up with the inlet manifold
  6. #46
    What curb ;-) Decade Plus User FF_Mark's Avatar
    Nov 2001
    Berkshire, UK
    26
    RChambers said:
    Not sure I'd want to trust those crimp connectors on a wiring loom, would be better to solder the joint and put heat shrink over the join.
  7. #47
    Aldershot
    4,538
    They aren't ordinary crimp connectors. First you crimp them, then you apply heat. The heat melts the solder in them that gives a good join. The heat also melts the glue in the plastic part making the join water proof and strong. Don't worry I didn't cut any corners. I was advised against standard soldered joints as they are prone to stress fractures.
    Richard
  8. #48
    Nov 2001
    Berkshire, UK
    26
    Sounds a lot better than the normal crimp ones
  9. #49
    Aldershot
    4,538
    Yeah they are pretty good but a lot more expensive than the standard crimps. Cost me more for the 5 I needed than for a pack of 50 normal crimps
  10. #50
    Racer Lee S's Avatar
    Aug 2003
    Liverpool
    1,640
    Should of used choc block terminals instead
    Ill get my coat.
  11. #51
    Aldershot
    4,538
    Or I could have used my Halfords install training and used scotch lock connectors . Nah even Halfords have banned them
  12. #52
    Jul 2002
    Cambs UK
    just twist and tape 'em it'll be fine!
    ahem
  13. #53
    Clint's Avatar
    Jul 2001
    932,389
    ahem
    Percy do you mean lenghen? just make up same spacers they are individual on the GSXR ones, some of the other bikes have 2 cast together which isnt very good for this.
  14. #54
    Aldershot
    4,538
    Yeah the top half is spaced out using spacers and the bottom part is bolted to a metal strip. Bigger spacers at the top and a redrilled strip at the bottom. Easy. Hardest part is to lengthen the linkages. Either weld new strip of metal on each one (not sure about the heat though) or just bend them inward until they reach
    Richard
  15. #55
    Jul 2002
    Cambs UK
    cool i didnt realise it was so simple. the whole TB unit you pictured looked fairly complex.
  16. #56
    Aldershot
    4,538
    When I strip them down I'll take some pictures. Should clear a few things up then
  17. #57
    Aldershot
    4,538
    Zetec Install - Throttle Bodies Fitted
    Well, the throttle bodies attached to the car now. And I have finished the wiring and tested the ECU on the computer. Gonna have to blag a laptop I think
    Richard
  18. #58
    World Champion Decade Plus User markb's Avatar
    Feb 2003
    Plumstead
    6,821
    10
    Re: Zetec Install - Throttle Bodies Fitted
    looks the part.. not sure about the mapping equipment though... what kind of laptop do you need and how long for? (ie couple of weeks? permanent? etc?) as I may be able to sort something out
  19. #59
    Aldershot
    4,538
    Well I have a base map loaded into the ECU now so I'm hoping that will run the engine well enough to get me to a rolling road (anyone know a good one near west london?). As for a laptop, if I need one it won't have to be very high spec. Anything that can run Windows 98 and has a small type com port would work.
  20. #60
    Aldershot
    4,538
    Getting excited now as its looking almost complete I think its looking quite smart, even if it desparately needs a clean
    Nearly there.
    Does anyone know what type of plug this is?? Its the same as the one for the TPS and I would like to fit a proper plug instead of crimp connectors.
    Worked out why the alternator bracket is giving me grief. The ST170 manifold is in the way! I'm sure Retro Ford have a solution as Dave is using the same manifold as me.
    If anyone wants any bits cleared up or pics of any areas let me know .
  21. #61
    Jul 2002
    Cambs UK
    when you gonna fire it up!
    needs the cam cover polished up! took best part of a week to polish mine up so i wish i got one of these instead:
    my mate Wootty sells them £34 posted (add £10 if you want anything etched on) see his site http://members.lycos.co.uk/sttdci/wootty/index.htm
    plus he sells loads of other zetec shiney bits. very cheap for top quality stuff. his cam pulley cover is pretty sexy!
  22. #62
    Aldershot
    4,538
    Not really too keen on that cover tbh. You can still see the manky standard part underneath. I will probably paint mine matt black as I don't want to take attention away from the throttle bodies
    Although I would like one of them BDA cam covers
  23. #63
    Jul 2002
    Cambs UK
    yeah i see what you mean. that cover is a replica of the ford racing one. for spark plug covers raceline does a nice subtle one (which i have got) or www.zxtuner.com have got a cool one in their "clearouts" section.
    so when is the engine gonna get started up in anger then? is there much left to do
  24. #64
    Aldershot
    4,538
    Here is the list of things to do...
    -Water temp sensor mounting
    -Rad plumbing
    -Starter motor
    -Fuel pump and piping
    -Throttle cable
    Basically all the annoying little jobs that I couldn't be bothered with until now
  25. #65
    Jul 2004
    Reading
    1,275
    I think that sensor is the MAP sensor, can't think what else it could be.
  26. #66
    Aldershot
    4,538
    Its a fuel pressure sensor as the ST170 doesn't run a return. Going to replace it with a regulator. Its just for illustration as the plug on the TPS is exactly the same.
  27. #67
    Jul 2004
    Reading
    1,275
    Right, got you. Looks like you need to go to a bike breakers, or find a gsxr in a quiet car park.
  28. #68
    Jan 2005
    lincs
    268
    looking good richard, keep it up mate
    to tell u the truth my enthusiasm had all but gone but seeing as your nearly there i really wanna get out there and get on. cheers mate. can you post some pics of how u have mounted your coil pack please mate iv got a nice 4 day weekend this weekend so wanna get all those niggly little bits done.
    cheers
    james
  29. #69
    Aldershot
    4,538
    I have kind of bodged the coil pack mount. It looks pretty cool though . Basically its the standard Mondeo coil pack mount turned upside-down and the bit sticking up is hacksawed off! One of the existing holes matches up to the mounting point for the water rail so its bolted on from that. Once I tidy it up a little and paint it, it should look pretty good. We have to have all the zetecs ready for summer so we can show people why its such a good conversion
  30. #70
    Jul 2004
    Reading
    1,275
    Sound good, mine should be on the road by the end of next month if all goes well.
  31. #71
    Aldershot
    4,538
    Good man Looks like we are about level then. Money (well lack of) is holding me up at the moment but I'm hoping to be finished by then too. We will have to meet up and compare when they are both on the road.
  32. #72
    Jul 2004
    Reading
    1,275
    It's the body work thats holding me up, but it's getting there. The only things that I have kept standard on my car are the doors (both need small repairs), bonnet, boot and thats about it!!!! I have changed so much, including 5 linking a capri axle, compression struts, steel bubble arches etc it has taken a lot of time. My only worry is I have never driven a rwd escort, what if i dont like it?
    We will have to get a meet going once there are some zetec escorts all finished, there is no doubts how good the conversion though.
  33. #73
    Aldershot
    4,538
    You will definately like the way Escorts drive. Even when I only had a 2 litre pinto it used to make me grin like an idiot everytime I drove it.
  34. #74
    Mechanic oliver's Avatar
    Mar 2004
    Powys
    558
    Mine should be done also very soon eta about 3 weeks. yay
  35. #75
    Pit Crew Decade Plus User TepiTheFinn's Avatar
    Jan 2003
    Finland
    1,226
    i bought 46mm throttlebodies out of Kawasaki ZX12R, arrived today.
    I also ordered ST170 manifold. Forgot to order rubber hoses, but i think i have to check first are they good for me.
    What's the inside diameter of the ST170 hose measured from bigger end ?
    Kawasaki injectors should be enough for me, i think i do the dual stage 8 injector setup. using std focus 2.0 blacktop injectors in st170 manifold. kawasaki injectors for wide open high rpm.
    Cheers,
    Tepi
  36. #76
    Jul 2004
    Reading
    1,275
    Are you sure those TBs wont be too big Tepi? Or are you going for 200 bhp +?
    The 8 injector set up will be smart though, very flash.
  37. #77
    Jan 2003
    Finland
    1,226
    nah...big is beautiful
  38. #78
    Pit Crew Decade Plus User ludsonline's Avatar
    Apr 2003
    Suffolk
    1,417
    I think they will be too big and you will lose bottom end power
  39. #79
    Jan 2003
    Finland
    1,226
    that can happen when talking about carbs with too big chokes, but it's a bit different with injection.
    but problems can occur with low speed driveability, caused by big changes in airflow when throttles open. this can be over come with progressive throttle opening. so that from idle to midrange throttles open very slow in relation to pedal travel.
  40. #80
    Aldershot
    4,538
    They look almost identical to my suzuki ones so they should bolt straight up to the manifold one you have spaced them out.
