convert mfi to efi?
ive got a rs turbo running mfi and a cvh engine with efi on it and wondered what was involved in changing them over and do i have to have the car set up afterwards cheerz
Re: convert mfi to efi?
Swap the heads, drill a hole for the CPS, and use the EFI inlet manifold. A lot of Fiesta RST stuff will be needed, like the ECU and MAP, also stuff like vacuum hoses with one way valves in them. It's a lot of work, maybe better to fit low comp pistons into the EFI lump.
cheerz mate. ur rite does sound like a lot of work only really wanted it to get rid of the air flow sensor box lol
Conversion plates are available for this type of conversion from mfi to efi, these save drilling any new holes or anything in your cylinder head. Try Jano at Odd Kidd Creations www.oddkiddcreations.co.uk
He also sells these from time to time on ebay
