Hi All,
I have a memory steer issue in my MK1 Escort that I would like to solve. Specs are below.
1972 Mk1 Escort 4 door
2L MK2 Escort struts
190lb 2" lower Burton Springs
Stock inserts
GAZ eliptical strut tops (Rose Jointed) I don't know the camber and caster settings however it just had a wheel alignment.
13"/6" Superlites with 185/60 road tyres
2.4 turn quick rack
Standard sway bar
Everything poly bushed.
Basically the car tracks straight however if I take a hard left or right hander and then straighten up it will pull to that side. If I take a corner to the opposite side it will usually track straight again. 2x turns to opposite side and it will start to pull to that side instead.
The quick rack is brand new. It was just fitted (Professionally) and a wheel alignment done. Exisiting tie rod ends were used when it was done. I think it was doing it a little before the rack was fitted however the lower ratio rack has made it more pronounced.
I was thinking it would have to do with the strut tops perhaps? I don't have the stock tops to put back in to try unfortunately and would prefer to keep the camber/caster change that these have given me.
Any ideas? I am away from the car now for 2 weeks but hoping to get some ideas to work on when I get home.
Nick
