Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 41 to 80 of 337
Thread: Mk1 Escort (Ratspeed) project build....
  1. #41
    May 2010
    london
    1,139
    Re: Mk1 Escort (Ratspeed) project build....
    Hi matt..thanks....it weighs 8kg...so not super light..but it is super strong...i can easly stand on it....that was my main aim..i looked at a lot of other spoilers and i could lean on them sideways and they just wobbled and moved...couldnt see the point if they had no strength....cheers mark
  2. #42
    Tyre Kicker Mondo H'n'S's Avatar
    Aug 2014
    County Durham
    17
    I am genuinely in awe of people who can take a totally rotten shell and rebuild it into something solid again, especially when they make the lion's share of it from scratch like you have!
    Superb!
  3. #43
    May 2010
    london
    1,139
    Quote Originally Posted by Mondo H'n'S View Post
    Superb!
    Thanks ..this site inspires people to have a go... cheers mark
  4. #44
    Mechanic davblue's Avatar
    Aug 2009
    ayrshire
    673
    some project there
    and talent
    now this sure is worth a watch
    keep up the good work m8
    southwest restorations
  5. #45
    May 2010
    london
    1,139
    Quote Originally Posted by davblue View Post
    some project there
    and talent
    Thanks...will post some updates when i get home tonight...cheers mark
  6. #46
    May 2010
    london
    1,139
    Fabbing the rear wing...i used 0.9mm ally for the the complete rear wing...i designed the wing so i could make 99% at home while watching the telly...using basic tooling...
    piece of 10mm diameter rod bent to the shape required....this was clamped to the ally and used to form the edge radius..with the good old hammer..
    The inner core poly block from the 99p store..
    strip of 1.5 mm x 20 mm ally strip. i used this to create an inner structure..and to give me a uniform finished width..(20mm + 0.9mm + 0.9mm)
    cut the side profiles (horse heads) with the tin snips 4 off the same..
    put the top bends on 2off l/h and 2off r/h...bent on the table edge...
    then using the rod as a forming template put a 5mm rad on the top and side edges with the good old hammer...
    i was going to ally braise the two halfs together..but after testing i changed my mind and decided to use 16mm flat head pop rivits
    i wanted to keep the surface flush so i needed to counter dimple the horse head sides for the rivits...
    so used the tool i made on my other project (down draught head)
    OB-round dimple tool (washer cut in half) this is for the adjuster slot to alter the angle of spoiler
    rivit block joiner ..these hold the two halves together..
    dimpled///with rivit blocks..
    assembly of the two halves...
    rivit the blocks to one side,,
    cut the foam core to size and shape (bread knife worked best)
    cut and fit the ally strips to the same side..
    and you end up with this..
    you can see the fixing bolts also installed...
    placed the other side on and rivited the two halves together....
    one side finished...and grain sanded tom create a 3d effect ..and the other side ready for dimples and assy
    you can see the two halfs and the 5mm rads where they meet...and also where the adjuster slot dimple will go...
    once the two halfs where assembled i used some black bumper(flexible filler) to fill the edges where the two halfs meet, to create a "factory joint"
    finished no paint just a polish..
    now on to the rear wing spoiler main..
    i decided to use the N.A.C.A flat wing design (most down force with least drag) almost flat top edge with a tail...
    i used a wing profile programme (plane....on the net) to size the actual wing and to get the correct shape..
    and built it the same as a plane wing...
    like this..
    so ..cut the inner assembly with the tin snips...didnt need to be super exact..
    the marked and drilled the fixing holes these all needed to be exact..as these would be my datum points..
    made a template with ply wood and using the fixing holes to secure(datum) ..bent the shapes around the former..i now have all my "ribs" formed and they are all exactly the same...
    i used thin wall ally tube to make the lateral strengtheners...all fixed with m8/6 ally bolts...
    the main nose shape (curve ) is the largest diameter and the ribs need the ends cut to accept this..
    First lay out of wing parts...before final fixing
    Next job is to join all the parts ...and then wrap in a single piece of ally sheet...
    later ...cheers mark
  7. The Following User Says Thank You to madragon199 For This Useful Post:
  8. #47
    Nov 2008
    london
    821
    88
    Hi I like your way of thinking, if you need any ally welding doing give me a call
  9. #48
    May 2010
    london
    1,139
    Quote Originally Posted by rick deregus View Post
    Thanks rick...yes more ally to weld..will give you a call....and thanks for the floor pans...all fitted a treat(with a bit of hammering)...cheers mark
  10. The Following User Says Thank You to madragon199 For This Useful Post:
  11. #49
    Mechanic Matt75's Avatar
    Mar 2011
    Melbourne
    797
    Fucking awesome. Im building a Grp 2 Zakspeed Replica and may just steal your design if that's ok. Your workis amazing.
    If you make a spare I'll buy it for sure
    Keep it up
    Matt
  12. #50
    May 2010
    london
    1,139
    [QUOTE=Matt75;2764306]Fucking awesome. Im building a Grp 2 Zakspeed Replica and may just steal your design if that's ok. Your workis amazing.
    Keep it up
    Thanks mate.. any pics of your project....
    heres some " diags" i used to work size and shape....no problem if you copy...if you need any advice just ask
    gives an idea of size...
    cheers mark
  13. #51
    Jan 2011
    clacton essex
    1,731
    70
    Erm, wow hardly discribes it, such a complex idea simplified to a diy process, I'm in awe that for dam sure,
  14. #52
    May 2010
    london
    1,139
    Once all the ribs ect were made...it was time to assy ...brought some ally m8 bolts..and cut them to length(cheapest available were 50mm long and anodised pink)..
    Then bolted all the parts together using yhread lock to secure..
    once was all assembled it was time to cover in a sheet of 0.9mm aluminium ..to make life easy and to get a square sheet..i ordered it cut to size...
    i then bent it in a sequence of bends using a piece of kitchen workto as the former....
    once bent i used a series of ratchet straps to hold the formed sheet tight to the inner structure while i drilled and rivited the hidden edges ..to form a ridged wing..(i used panel adesive on the tops and base of the ribs to make sure i had a good contact all round...)
    Check fitting the end supports...
    Thats as far as i can go ..untill the car is widened and a can make the base support and decide how high to set the wing...
    Back on to the car steel work next
    cheers mark
  15. #53
    Mar 2011
    Melbourne
    797
    This is awesome. I'll def look into making this too.
    I've only just started my Zakspeed project but I'm taking inspiration from you.
    Can't wait to see ehat else you come up with.
    Matt
  16. #54
    Aug 2015
    Leeds
    767
    The work you have put in the is awesome and the craftsmanship is 2nd to none
  17. #55
    May 2010
    london
    1,139
    Thanks guys...
    Back to the shells metal work..
    Finished the two halves for the cross brace..ready to be welded together..
    Welded the new tunnel floor in place... i had to pull the shell into square across the corners...used a ratched strap...worked a treat...welded in place and released ratche strap...and stayed dimensionally good....
    the next jobs are...4 link boxes weld in...cross brace weld in...firewall lower brace weld in...and remove the old chassis rails....of course everything has to happen at once....its all tied together....
    trial fit of parts....
    I already had these 4 link boxes came in the boot of another car...so used them...i went as high as posible to get the car as low as posibble (if you no what i mean) i will make the axle bkts offset to fine tune the finished height.
    bits of string g clamps and a big hammer to check fit....
    happy with fit so removed and cut out the old chassis rails...
    I will get to these later
    4 link boxes jigged ready to weld..
    cheers mark
  18. #56
    Pit Crew gorilla1q's Avatar
    May 2009
    Cheshire
    1,345
    67
    Cracking build so far with some excellent work, I love it
    When I grow up I will have a MK1 Escort
    I must be all growed up now then and paying for it!
  19. The Following User Says Thank You to gorilla1q For This Useful Post:
  20. #57
    May 2010
    london
    1,139
    Welding begins...
    next is the fire wall lower brace....i am replacing the inner wheel tubs with some mk2 escort purchased from here....so its a temp weld untill the chassis rails are replaced...
    The diff tunnel has no ribs across the top because the next brace will address this..
    This piece ties the cross brace to the diff tunnell and reinforces the cross rail(hides the join) and will give the tunnell some cross strength...
    All the parts welded...(top side only at moment...when i get some strength in the shell i will spin her over)
    Made a gusset to tie the cross brace and the door jam together...
    Before...(this is where the new(old) floor was welded to the old(old) shell..
    After... Hides and reinforces the join
    Next job is to make some chassis rails....i got the centre sections of e bay 15 each...so just the rest to make..
    i ordered some 1.6mm m/s sheet..
    but before i start to cut i need to see where the wheel and axle sits....
    so a quick mock up with the wheel.....im using a 15" x 10" wheel ..
    This is where i want the wheel to sit....
    cheers mark
  21. #58
    May 2009
    Maesteg South Wales
    2,041
    142
    Impressive work mate well done
  22. #59
    Oct 2015
    Gloucestershire
    Amazing work, buddy. look forward to seeing updates
  23. #60
    May 2010
    london
    1,139
    Next step was to fit a tyre and set the ride height....
    Tyre is p7 285x40x15....when fitted measures 295mm x 595mm...
    i had to remove some metal to make room...
    The end result ..i need to make 75mm clearance on the chassis rails....i cant notch them as they are only about 55mm deep...
    so the plan Make some new ones....my old chassis rails were toast...so i was always going to make new ones..
    The plan see pic below......
    So i invested in a sheet of 1.6mm tin and started cutting and bending....i made the chassis rail in two parts
    and even though im not using springs i built the spring hangers/skids...which needed to look factory and keep the datum hole in the correct position..but because my new chassis rail is altered..they are a complete new design
    pics as it happened..
    One side finished one to go....
    Started cutting the arches out ....inner and outer are going as the inner tubs are just rust...i strengthened the shell again...
    then started cutting (after a lot of measuring)
    Im going to use mk2 escort inner tubs..these are staying standard..and are being kept for the turrets to mount on.....the actual wheel and axle combination takes the wheel past the tubs...
    The body will be stretched 8" ...4" on each side and then the arches will be fitted.
    cheers mark
  24. #61
    May 2009
    Maesteg South Wales
    2,041
    142
    Looks great well done
  25. #62
    Spanner Monkey QuIcKrAcK's Avatar
    Jan 2007
    LONGFORD IRELAND
    204
    Be the good feck lad, that is a project and a half.
    Love it man!
    1700cc MK1 ESTATE DONE. MK1 2DR STARTED
  26. #63
    Jan 2011
    clacton essex
    1,731
    70
    How are you gunna stretch the body 4 inches each side
  27. #64
    Dec 2011
    Northamptonshire
    731
    Massive project and goes to show what can be done
    More of our work can be found Facebook give us a like:
    https://www.facebook.com/JD-Automotive-Ltd
  28. #65
    May 2010
    london
    1,139
    Quote Originally Posted by rwd2ltrfiesta View Post
    This is the plan...
    Cheers mark
  29. #66
    Jun 2014
    Scotland
    22
    Why are you doing that rather than just binning the old tubs and putting new ones in? I would have thought that with the raised chassis rails the old tubs would be obsolete - but I've never done anything like this, so I'm probably missing something fundamental.
    Superb project, really well done.
  30. #67
    May 2010
    london
    1,139
    Ok..so the chassis rail is ready to weld..and the mk2 escort inner well is ready to weld...but before i can do any of that i need to make the new moosive inner tubbs ...these will tie the inner well. the existing body shell...the new body shell...and the provide attachment for the bubble archs..
    the diameter of the tubbs are 1200mm...
    because the rolled edge is so long about 1650mm i made this part in two halves...and welded them together..
  31. #68
    May 2010
    london
    1,139
    Quote Originally Posted by GMB77N View Post
    Yes i could of....but i want to keep the inside looking factory...and it gives me my coilovers turret mount position...cheers mark
  32. #69
    Jun 2014
    Scotland
    22
    Quote Originally Posted by madragon199 View Post
    Cool. Look forward to seeing it come together.
  33. The Following User Says Thank You to GMB77N For This Useful Post:
  34. #70
    May 2010
    london
    1,139
    So onward and upward....
    pics of the making of the new tubs...
    The metal for the rolled edge its 850 x 300mmm and theres 2 off
    Using an oil drum and a ratchet strap to form my radius edge...it doesnt matter that the oil drum is to small..when the radius is formed its easy to flatten out the curve to the 600mm rad....
    when both halves were made a welded them together....
    then trial fitted it to match the cut i made earlier in the shell...
    while its in position i will use it as a template to cut the inner piece...
    marked with sharpie
    cut and seam welded on the inner face..to create a folded edge..i will lay some tacks down later on the front edge..
    1000mm diameter...
    need to rough trim the inner edge then re fit and mark the m2 escort well position and remove cut and weld...ect
    all for now cheers mark
  35. #71
    Sep 2014
    Ipswich, QLD, Australia
    47
    This is fantastic!! Great fab work mate, this is going to look mint!
    Project 1 Mk1 RS2000 replica, now home.
    Project 2 Mk1 Escort Turbo Duratec, in the planning stage
  36. #72
    May 2010
    london
    1,139
    Quote Originally Posted by Cort500 View Post
    Thanks ...
  37. #73
    Jan 2011
    clacton essex
    1,731
    70
    This is the plan...
    Cheers mark
    Simples then
  38. #74
    May 2010
    london
    1,139
    Simples then
    LOL...seemed a good idea at the time...
  39. #75
    Mechanic bodger rogers's Avatar
    Oct 2008
    bristol
    47
    865
    great work mate love the fab
    if it aint broke, break it!
  40. #76
    May 2010
    london
    1,139
    small update...dry fit/cut...no welding yet...
    dry fitted the chassis rail....i had left the leaf spring attached to the shackles so i could get an easy fitting reference
    then fitted the new outer tub in position
    then trimmed the mk2 inner arch to fit between the chassis rail and outer arch
    then marked the cut line for the new outer arch...
    that took a whole day
    to keep busy while watching the tele at home i started prepping the sh#t rear fiberglass arches that were on the car...
    because they are single layer and been abused...my plan is to make them in carbon fibre...
    i am going to use these as the meat in a carbon fibre sandwich...so fill, sand,prime,sand,paint,sand,fill ect
    cheers mark
  41. #77
    Mar 2011
    Melbourne
    797
    Loving the flares.
    Matt
  42. #78
    May 2010
    london
    1,139
    Quote Originally Posted by Matt75 View Post
    Loving the flares.
    Matt
    Thanks matt....hope it inspires you to finish your build...cheers mark
  43. #79
    Mar 2011
    Melbourne
    797
    Cheers Mate,
    I've just stripped the carso work can begin soon.
    I'll post some pics as it develops more.
    Matt
  44. #80
    May 2007
    Vic, Australia
    662
    133
    This is simply awesome.
    Loved the downdraught head and great to see such an equally unique engineering masterpiece for it to go into.
    You sure do have some fabrication skills and a way solving problems.
    Keep up the write up.
    Shaun
