Page 2 of 2 FirstFirst 1 2
Results 41 to 49 of 49
Thread: HOW TO FIT A ZETEC - Part 1 - Fuel System
  1. #41
    Apr 2014
    South Africa
    72
    Re: HOW TO FIT A ZETEC - Part 1 - Fuel System
    Alright cool, so I have a mk3 xr3i and the fuel relay has packed up.Can I use any relay or does it have to be a fuel pump relay and if it does have to be a fuel pump relay then can any fuel pump relay work or does the xr3i have a specific one?
  2. #42
    3,242
    Could say for sure if its installation specific or not - sometimes manufacturers tie all sorts of circuits together! With aftermarket ECU's a simple std 4 pin relay does the job - battery to 30, pump to 87, ign 12v to 85 and 86 to ECU (switched to ground to operate)
  3. #43
    Apr 2014
    South Africa
    72
    Hi katana.thanks for that .think I'm gonna try a normal 4 pin relay as per your suggestion.im sure the original ford fuel pump relay commands it's price!!!!
  4. #44
    Apr 2014
    South Africa
    72
    Hey some good news katana!!!!it would seem my aftermarket ecu does come with a fuel pump relay.welll im sure it is so because it does connect to the ecu as per my wiring diagram
  5. #45
    Jul 2015
    Blackpool
    Hi this mabye be a long shot but.when u wired the 12 wire plug u dont by any chance know wat colour of wires are wat do u thanks
    I know this is a old post but worth a try as im currently trying to wire this same engine and manifold as urs any little help would be appreciated
  6. #46
    Dec 2015
    Frinton on sea
    10
    Thanks for this post very interesting
  7. #47
    Tyre Kicker new1's Avatar
    Jun 2016
    Moscow
    31
    32
    I'm looking up to updates and here's my little effort.
    Here is a fuel rail from a '93 mondeo 2liter. I've also bought an intake of some zetec escort, supposedly 1.8, rail and injectors are same. Both are sidefed. The scoprio 2 injectors also does look the the same.
    Click image for larger version Name:	A8EDA_V2Bfk.jpg Views:	115 Size:	20.0 KB ID:	78915
    I've also had some 4age injectors (from silvertop lump i guess), but bodies differs.
    Click image for larger version Name:	mhaBItKgWpA.jpg Views:	117 Size:	28.1 KB ID:	78916Click image for larger version Name:	JRm8UXdtclY.jpg Views:	116 Size:	58.1 KB ID:	78917Click image for larger version Name:	PQrKC2766fU.jpg Views:	116 Size:	29.0 KB ID:	78918Click image for larger version Name:	MdTJRoKd1RU.jpg Views:	116 Size:	57.4 KB ID:	78919
    I also know the later cars had top feed injectors, but can't say anything about that yet.
    It rusts!
  8. #48
    Jun 2016
    Moscow
    31
    32
    Can anyone confirm fuel rail interchangeability? I have a 2.0 s2 silvertop with an escort intake and fuel rail wich is sidefed. I want to know if somebody has done a topfeed conversion i.e. if the black top rail will work.
    It rusts!
  9. #49
    Oct 2019
    San Francisco, California
    10
    SCS-Delta might be a good source for fuel injection / engine management systems:
    https://www.scs-delta.co.uk
