Results 1 to 18 of 18
Thread: Trimming a manta sump flat?
    Pit Crew Decade Plus User onecamohv's Avatar
    Jun 2012
    ireland
    1,155
    Hi Chaps, has anyone ever mounted a manta sump with a zero degree bellhousing and trimmed the bottom corner off flat?
    A mate donated it to me for free so it would be a shame not to use it and I want to mount the engine straight.
    I need it to fit under a sump guard, it cant be drooping down, anyone ever done it? does much of it hang down below the xmember?
    Pit Crew Decade Plus User MegatronUK's Avatar
    Jun 2006
    Durham, UK
    1,494
    Re: Trimming a manta sump flat?
    With a 7 degree bellhousing it does stick down, unfortunately I never took a detailed photo of it. Here's the closest thing I have:
    Click image for larger version Name:	sump.jpg Views:	194 Size:	76.7 KB ID:	76668
    I think with a 0 degree mounting it would probably be just about in line with the bottom of the crossmember, though it probably depends on the mounts you're using. It will be close though, no doubt about it.
    Jun 2012
    ireland
    1,155
    hmm im confused, yours looks to be sitting lower on the drivers side, which means with a 0 degree bell housing it would be more level?? i assumed using a manta sump with a 0 degree bellhousing would have the sump dropping even further down?
    Jun 2006
    Durham, UK
    1,494
    Yes, I think we're saying the same thing; a 0 degree bellhousing should bring it more level; though perhaps still just below the level of the crossmember.
    World Champion Decade Plus User meXEco's Avatar
    Mar 2003
    TRURO
    5,250
    246
    Eh? A 7 degree b/h should see the sump sit flat, 0 degree would see it drop on drivers side which that pic looks like it has.
    Plymouth
    899
    only time you might need to trim a manta sump is on the ns when fitting a btb or tony law manifold
    Nov 2008
    Bored
    1,380
    Still got the sump
    Jun 2012
    ireland
    1,155
    Quote Originally Posted by meXEco View Post
    correct thats what i was thinking - it looks like that car has a manta sump with an upright engine.
    I have a manta sump there, but i need to use a forestry spec sump guard bolted to the xmember - so i will need to trim a portion of the bottom corner off level with the xmember to clear the guard, but how much is safe?
    Jun 2006
    Durham, UK
    1,494
    Quote Originally Posted by onecamohv View Post
    Yeah, sorry. Can't explain that. Mine has a manta sump, and a 7 degree bellhousing. I suppose it's possible that SBD supplied the wrong one when I bought it some ~13 years ago.
    Jun 2012
    ireland
    1,155
    yeah i guess thats possible - as the manta sump is supposed to sit dead flat with a 7deg bellhousing - i have the engine up on the stand now so i can pop on the manta sump, take some measurements off the xmember and get a pretty good idea of how much would stick down.
    Plymouth
    899
    if you use a piece of fuel pipe inside a piece of heater hose to stop it collapsing then place it between the sumpgaurd and cross member, should have some clearance and also stop it vibrating against the xmember
    Jun 2012
    ireland
    1,155
    cant lower the guard any more, need as much ground clearance as possible !
    Plymouth
    899
    7 degree bh and redo your engine mounts
    Jun 2012
    ireland
    1,155
    dont want it mounted at 7 degrees!
    Jun 2012
    ireland
    1,155
    just said id update this as i got around to it this weekend - worked a treat - my 7degree manta sump is now bang on level with the xmember
    Jun 2014
    cavan ireland
    26
    I've the same set up, just wondering how much of a wall do you reckon is left on the sump where u have it grinded???
    Jun 2012
    ireland
    1,155
    im not sure what you mean? i cut the bottom of the sump off and welded a 3mm thick plate to it
    Jun 2014
    cavan ireland
    26
    Ah I see... No I misunderstood you, I see what you done now����
