Lotus Talbot 2,2 ZF gearbox propshaft
Does anybody know the Lotus Talbot 2,2 with 5 speed ZF gearbox has the same splines and same diameter for the propshaft as the one fitted to Ford and Opel and others?
Did the Ford auto gearbox propshaft fit this gearbox. I believe it was the case with Opel.
I have to fabricate a propshaft for my dyno so I can fit the engine including the box. If someone out there got the right joke or propshaft, I'm willing to buy this.
Re: Lotus Talbot 2,2 ZF gearbox propshaft
You could ask the guys from Biesheuvel Autosport in Nederland, they run a Talbot Lotus.
http://www.biesheuvel.nl/
The Following User Says Thank You to Miniliteman For This Useful Post:
Will call them asap. Thanks Leon
Zf gearboxes for the Escorts, Sunbeams and Opels has the same mainshaft and the same tailhouse. Than the propshaft nose has the same sizes and spline.
www.gr-box.sm
