In the middle of this conversion... Just wondering, are people using an Oil cooler as part of this install!? As the Vauxhall engine i have already has the outlets for this above the oil filter!?
I have a Modified head which has had the distributor housing machined flat at the back, so i assume i have got to fit a blanking plug!? Are these available? Finally, with regards the Cams, do kent do a modifed item minus the drive for the distributor?
Fortunately i have had a result and got myself a pair of webber alpha's, with loom, ecu, fuel pump etc for £600! Thus freeing up a few pence for the build!
Thanks in advance for your help!
