Results 1 to 7 of 7
Thread: xe rad hose
    Spanner Monkey HOSSMAN's Avatar
    solihull west midlands
    359
    21
    xe rad hose
    hi need to get some rad hoses what do you xe guys use
    not using heater matrix
    m2 escort with radtec rad
    both rad ends are straight
    engine at 7 degre
    Plymouth
    899
    Re: xe rad hose
    bottom hose i bought a 180 bend and then had to use a joiner to the bottom, top house i used an omega top house from a 2.0 ecotec
    3,641
    359
    21
    Re: xe rad hose
    Thanks again guys just bought them from motorsport tools
    Bodger Turbosport Subscriber
    Mar 2009
    isle of arran
    Re: xe rad hose
    So with these hoses from Motorsport tools, where do you run the hose from the inlet manifold to? can you just blank it off? or does it not have to join into the bottom radiator hose? Im not using a heater matrix either.
    Jan 2009
    Ireland
    195
    9
    Re: xe rad hose
    Quote Originally Posted by ARRANRS View Post
    Im interested in know this myself as I am running No heater matrix.
    Did you get an answer?
    [SIGPIC]
    Jun 2012
    ireland
    1,157
    Re: xe rad hose
    its highly not recommended to block the inlet manifold water outlet, thats where the coolant recirculates when the thermostat is closed.
    just use a T piece to join it into the hose coming off the back of the water pump if your not using the XE water rail
