Re: Atlas + 3i discs?
No mate, thats perfectly normal, you need to turn a couple of mm off the OD of the halfshaft flange, and put a bit of a chamfer on the outside edge too to clear the rad on the inside of the disc "bell". Literally a 30 second job for someone with a lathe...
hope this helps
Tom
You mean like mine?
As above, a little bit of work on a lathe and you are sorted.
It's an XR4x4 handbrake cable that is rigged up to work as the callipers are of the floating variety. Of course the hydraulic handbrake does all the work really. Hopefully it will get through the MOT like that.
OK no bother, but why are you getting new discs? I'm sure it'd be easier to find someone with a lathe who's prepared to do you a guvvy job. I guess it might be tricky finding another disc which is the correct (same) diameter, thickness, offset, but with a bigger ID bell? Is your call though. Gimme a shout if you get stuck.
cheers
Tom
Just found these which should help explain if anyone is thinkin wtf.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...542332322&rd=1
Yes a lathe is ideal but I've turned down the flanges with an angle grinder before as it's only a couple of mm, saves taking the axle apart as well
