Page 1 of 2 1 2 LastLast
Results 1 to 40 of 73
Thread: How to Fit 2wd Cossie 4 Pots to RWD Escort.
    Clint's Avatar
    Jul 2001
    932,359
    I have been doing this conversion for a few years and I personally think its a great little setup, why? well the cossie 4 pot is one of the best 4 pots about, albeit a little heavy prehaps but its got amazing clamping force, its has four 40mm pistons a very rigid body.
    I use a disk from rally Design (which is a replacement disk for thier willwood kit) for the base of the conversion part number BD13/285. This fits directly to the rear of the hub with the standard fittings.
    A bracket needs to be made which I do with 13mm plate, I dont have a pattern I simply drill the first hole and mark up the rest one at a time, use a piller drill to ensure the holes are parrellel, one all the holes are in I measure the disk centre and then get a local machine shop to surface grind the braket to the required thinkness (around 11.5mm).
    The caliper will need the webbing removed between its mount holes to clear the bracket to hub mounting bolts.
    This conversion will need a 15" wheel to clear, the ideal master cylinder size is 5/8th of an inch (0.625)
    Heres a few pics of the conversion:
    Oct 2003
    wales
    331
    Re: How to Fit 2wd Cossie 4 Pots to RWD Escort.
    Top man! would it be possible to use the sierra disc?
    Clint's Avatar
    Jul 2001
    932,359
    You might be able to use a 4x4 cossie one but I still think the offset is wrong, havnt got one here to compare, but you would need to machine the centre and the mounting holes, by the time you have done that it would be cheaper using the Rally design disk.
    Oct 2003
    wales
    331
    Its just that i've got brand new 2wd discs
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Is there no way to get them under 13" wheels at all, my bro has a set of callipers and i have 13"s
    Mechanic DanR's Avatar
    Jan 2005
    high wycome
    601
    do they do those discs drilled or grooved??
    and how much?
    Clint's Avatar
    Jul 2001
    932,359
    and how much?
    Not sure why you would want drilled or grooved disks but I am sure they could if you asked them.
    TURBOSPORT SPONSOR Decade Plus User
    Turbosport Sponsor
    GP4's Avatar
    Sep 2003
    Carmarthenshire
    1,607
    Well a mate of mine has them on a road rally Mk.2 Dave, and that's on 13" RS alloys. So...yes, they will go under 13" rims!! Next time I see him I'll look at the car to see how they've been fitted and let you know.
    It's always surprised me that this setup isn't more common on Escorts. They're more powerful than Princess 4-pots, the same sort of weight, and half the price. I suppose that most people can't be bothered to make a bit of an effort to get them fitted, whereas a Princess caliper bolts directly on.
    Clint's Avatar
    Jul 2001
    932,359
    This conversion will not fit under 13" wheels, you may however be able to get the calipers under 13" wheels if you use smaller 260mm disks.
    Oct 2002
    London
    15,132
    65
    Yea if you can get some pics of the setup on that escort it would be nice
    I might have to have a play then
    Mar 2003
    TRURO
    5,250
    246
    Clint i take it from the product code these are 285mm discs??
    Clint's Avatar
    Jul 2001
    932,359
    Yes m8 285mm
    Pit Crew Decade Plus User ludsonline's Avatar
    Apr 2003
    Suffolk
    1,417
    Any idea how much these are as they are not listed in the catalogue?
    Mar 2003
    TRURO
    5,250
    246
    Ditto-i tried looking online with the code but nowt came up??
    Mar 2003
    TRURO
    5,250
    246
    Clint do the discs for this conversion sit further out from the hub than standard escort discs-as the bracket mounts push the caliper out (or in whichever side of the bracket you mount them?)
    Ie do you mount the calipers outboard of the bracket, or inside (nearer inner wing)-i'm guessing outside??
    Dec 2003
    London
    10,228
    26
    i recognize those calipers
    Clint's Avatar
    Jul 2001
    932,359
    you certianly do kev
    Pit Crew Decade Plus User rich_mkii_rs2000's Avatar
    Feb 2003
    Haverhill
    1,096
    17
    anyone thought about XJS calipers
    been trying to find some dimensions on them,
    they take a 284x24mm disc
    also have 48mm pistons
    not sure if they would fit under 13inch wheels though
  19. #19
    Mar 2003
    TRURO
    5,250
    246
    Standard Rally Design replacement 285 disc-£40 each, x-drilled-£55 each.
  20. #20
    Apr 2003
    Suffolk
    1,417
    What about Range rover caliper they are 4 pot & have 41mm pistons?
  21. #21
    Pit Crew Bart2207's Avatar
    Jun 2004
    Netherlands
    816
    Quote Originally Posted by meXEco
    Do you have an article number for these discs?
    Thanx
    Bart
  22. #22
    Mar 2003
    TRURO
    5,250
    246
    BD13/285-replacement discs for willwood big disc kit mk1/2.
    Product code doesnt come up though-i rang them for price.
  23. #23
    Jun 2004
    Netherlands
    816
  24. #24
    Bodger CortinaCosworth's Avatar
    Dec 2004
    Norway.
    Hi!
    Is that the ONLY disc that will fit?
    The RS500/2wd-Cosworth disc "BM203",283/24 they have at Rally Design,doesn´t fit ??
    Eirik.
  25. #25
    Jun 2004
    Netherlands
    816
    Quote Originally Posted by Clint
    I don't hink the RS500/2wd discs will fit
  26. #26
    Apr 2003
    Suffolk
    1,417
    You can buy brand new remanufactured 4 pot RWD Cossie calipers from http://www.brakeparts.co.uk for £51 ea +vat & P&P
    Attached Thumbnails Attached Thumbnails Image2.jpg‎
  27. #27
    Clint's Avatar
    Jul 2001
    932,359
    Quote Originally Posted by ludsonline
    Amazingly cheap !
  28. #28
    Dec 2004
    Norway.
    Hi!
    What kind of hubs have you used? Grp 4??
    Eirik.
    Attached Thumbnails Attached Thumbnails RD199.jpg‎
  29. #29
    Clint's Avatar
    Jul 2001
    932,359
    They are Group4 hubs converted to normal wheel nuts.
    The conversion will work with original hubs though.
  30. #30
    Dec 2004
    Norway.
    Hi!
    Ok,thanks!
    Eirik.
  31. #31
    Dec 2004
    Norway.
    Hi!
    The RS500/2wd-Cosworth disc "BM203",283/24 did NOT fit,I checked it today.
    Just have to send them back to Rally Design and change them into the BD13/285 discs...
    Here´s a link to their brakekit,with the discs.....
    http://www.rallydesign.co.uk/catalog...oducts_id=3925
    Eirik.
  32. #32
    Mechanic JimmyJames's Avatar
    Jun 2004
    London
    557
    Hi, Does anyone know if using the cossie calipers on 2.8i struts with the vented discs from a 2.8 capri, would work on 13in's. has anyone done it, wouldn't the brackets move the caliper over and not have the disc in the centre of the caliper or would it be fine. or is that the reason for after market discs.
    cheers james
  33. #33
    Oct 2002
    London
    15,132
    65
    As far as i understand it the webbing where the bolts go on the calipers is too long and sticks the callipers into the wheel? Otherwise i feel it would be a popular mod if you could get them under a 13"
  34. #34
    Oct 2004
    hampshire
    22
    So forgive me if this is a stupid question but can you use 2wd cossie brakes front and rear on a mk1 escort or not?
  35. #35
    Bodger JudgeFudge's Avatar
    Jan 2004
    Yorkshire
    Quote Originally Posted by dangerousdave
    So... Anybody got this setup under a 13" wheel yet??
    Paul
    MkII '80 RS2000 in signal red - SOLD
    '91 Pug 205 Gti 1.9 - SOLD
    - Trackday nutter shed wanted -
  36. #36
    Sep 2005
    has anyone ever fitted 4 pots to a mk2 escort i know its been done to cosworths and fiestas.
  37. #37
    Nov 2005
    preston
    284
    your a star if you counld post some pics it would got mint do you have the no of rally design matey
  38. #38
    Clint's Avatar
    Jul 2001
    932,359
    Pics now back
  39. #39
    Nov 2005
    Cheshire
    112
    Could you be more specific in what adjustments need to be made to the calipers? I don't understand which part needs removing?
    I spose you've been asked before but.....any chance of making me up a pair of brackets? Or a cardboard template?
    Thanks a lot, Aid
  40. #40
    Nov 2005
    preston
    284
    hi dose any one have the no of rally designs please
  41. The Following User Says Thank You to graham c For This Useful Post:
