Results 1 to 26 of 26
Thread: suspension overhaul mk1 escort
    Oct 2011
    Netherlands
    22
    14
    hello all,
    this is my first post on here about my mk1 escort
    it started life as a standard 1300, 4 speed
    drove it a couple off years ike that
    then it got a rebuild 1660 cc crossflow
    twin 40 webber carbs
    stage 2 head
    1300cc pistons
    kent cams BCF3 cam
    its been like that for the last years, but never really liked the handling
    Oct 2011
    Netherlands
    22
    14
    Re: suspension overhaul mk1 escort
    This year it got a bog upgrade
    rear:
    Rebuild and narrows atlas axle, 3,77
    Cosworth rear calipers
    Gaz shocks
    Anti tramp bars
    Watts linkage
    new axle disassembled
    measuring and setting up the new axle for shortning
    drilling out the welds
    shortend the half shafts
    the shortend axle
    welding the brackets on
    all painted
    Oct 2011
    Netherlands
    22
    14
    front end
    all new bushes
    anti dive kit
    adjustable TCA
    Coil overs
    Spax inserts
    Midilite calipers
    Power steering conversion
    New quick steering rack
    setting up the power steering
    coilovers
    also converted to t9 5 speed
    cleaned everthing up and all fitted with new bushes etc
    some general pics, everthing got cleaned,sand blasted and painted before installing
    shortend axle tube
    cleaning the leaf springs
    all painted
    during rebuild
    rear axle setup
    pedal box
    front rebuild
    current stand after rebuild, very happy with it, handles like a go-kart
    Jun 2006
    Durham, UK
    1,494
    Nice looking mk1!
  5. The Following User Says Thank You to MegatronUK For This Useful Post:
  6. #5
    Aug 2006
    Christchurch, New Zealand
    463
    Very nice work
  7. The Following User Says Thank You to Pikey15 For This Useful Post:
  8. #6
    Sep 2004
    Ireland
    354
    18
    how much did you narrow your axle and how did you shorten your halfshafts.
  9. #7
    Oct 2011
    Netherlands
    22
    14
    I narrowd it 35 mm on both Sides, 70 mm in total so its about 47-47,5 inch,its mk1 capri axle, so 50inch standard?? with 10 mm spacer on each side the total with at the front and rear Wheelbase will be the same.
    The halfshafts where cut in half in the middle, shortend 35 mm, turned down to 15mm at 1 end and drilled out to 15 at the other end on a lathe on a tight fitting, then used a press to put them back together making sure everything was back in line.
    After this welded them together(tig) and they got balanced and checked for straitness.
    Its a job, but with some planning and thinking it thru not a to difficult job( atleast if they hold )
  10. #8
    Sep 2004
    Ireland
    354
    18
    thanks for the info,before you welded the 2 halves back together did you use much of a vee to fill with weld.by the way you have a very nice car sir.
  11. #9
    Oct 2011
    Netherlands
    22
    14
    tought it was about 5mm both sides, so a v of about 10 mm, thx for the compliment
  12. #10
    Oct 2011
    Netherlands
    22
    14
    My new project
    After running the car for a couple off weeks ive got a new idea.
    The speedo is ways off after changing the axle and converting to a 5 speed box, 100 km/h is about 140km/h on the speedo.
    The fuel gauge reeds about 1/4 tank to low and the rev counter keeps going all over the place, very annoying
    The plan is to build a custom 6 dial cluster, but keeping the original look, however i dont want to rebuild my original cluster for this, so ordered a glasfiber unit and sourced some dails that i liked.
    after setting it all up the holes had to be drilled
    first holes drilled
    and a trial fit oh yes it fitsssss
    then it was time for the big holes
    with the dail in
    and last one off how it looks like with a quick paint and the dails in, still have to search the speedo en voltage dails.
    Thinking of going the electronic route with the speedo, so its programmable to whatever wheels and axle i use.
    anyone have any experience with electronic speedo's? i want to have the smiths 80mm dail, witch needs a pickup sensor that costs about 55 pounds. Does anyone know if i could use any 12v pickup sensor? ive got some for free at work
  13. #11
    9,200
    Get the smiths spec ie voltage and Pnp or npn etc then match from stock?
  14. #12
    Oct 2011
    Netherlands
    22
    14
    another small update, had the dials delivered and started the wiring.
    very happy with how it looks, somewhat original to the standard 6 dial dash.
  15. #13
    May 2007
    762
    Goe bezig Roy !
  16. The Following User Says Thank You to racing escort For This Useful Post:
  17. #14
    Oct 2011
    Netherlands
    22
    14
    Hi All,
    just finished putting a zetec into my mk1 escort, drives great,
    Only problem i have that its blowing oil out off the top of the oil catch tank.
    got 1 line coming from the top off the valve cover and one from the breather hole on the block.
    Could the problem be the return i have made back into the sump? that the pressure is to high for the oil to run back into the sump and so is filling up the catch tank?
    at the first pic you can see the setup.
    regards,
  18. #15
    Feb 2016
    Nottingham
    25
    top work mate its a lovely looking car just building one myself
  19. The Following User Says Thank You to Jpm-lfc For This Useful Post:
  20. #16
    Dec 2009
    Netherlands
    413
    19
    Te gek! Wanneer kan ik op de koffie komen?
    Amazing work
  21. The Following User Says Thank You to Ruudje For This Useful Post:
  22. #17
    May 2007
    762
    Should the oil catch tank not be mounted higher (equel to top of engine) ?
  23. The Following User Says Thank You to racing escort For This Useful Post:
  24. #18
    Oct 2015
    Essex
    347
    33
    The Oil return to the sump should b below the oil level in the sump to stop it being pressurised :-)
    Sent from my Bavs iPhone
  25. The Following User Says Thank You to Ianbavs For This Useful Post:
  26. #19
    Feb 2016
    Vila de Cruces Galicia Spain
    21
    Do you have problems with tyre rubbing in the rear arches???. I'm thinking about 7" Superlites with English axle, but some people don't recommend it with the original arches
    Oct 2011
    Netherlands
    22
    14
    no i dont, shortend the axle, so no problems, only on the front sometimes
  28. #21
    Feb 2016
    21
    Quote Originally Posted by RoyP1982 View Post
    Is the new axle more narrow than the english one??
    Thanks a lot for your answer
  29. #22
    Oct 2011
    Netherlands
    22
    14
    its about 47 to 47,5 inch now. dont know how wide an englisch axle is. but got 10mm spacers on also
  30. #23
    Tyre Kicker Marquito2004's Avatar
    Aug 2006
    Lisbon Portugal
    Mine is the same colour as yours is, but much more stock. 1.3 gt mk1. Mate yours is so beautifull and such quality mods you have there. Congrats mate.
    We have a big problem here in Portugal. Such restrictive laws concerning car inspections dont allow us, at least legally to exchange car engines. One thing id like to do in mine was to get rid of the stock 1300 gt xflow and to get one zetec just like yours. Once again god job.
  31. The Following User Says Thank You to Marquito2004 For This Useful Post:
  32. #24
    Nov 2015
    Netherlands
  33. The Following User Says Thank You to FordRSmania For This Useful Post:
  34. #25
    Oct 2011
    Netherlands
    22
    14
  35. #26
    Oct 2016
    Sheffield
    33
    11
    Lovely Mk1 that mate. I need to get a shift on with mine haha!
  36. The Following User Says Thank You to Deano1990 For This Useful Post:
