Results 1 to 32 of 32
Thread: twin 40 jets any good?
    Mechanic marshyboy2002's Avatar
    Aug 2013
    Worcester
    523
    20
    Hay guys have taken one of the carbs now to go for the rebuild and just wondering the jets are sized right for the 2l pinto
    Jets are
    Progression 60 f5
    Pump jet 45/35
    Main jet f16/125
    Idle jet 45/f8
    I would say now is the time to change them if needed as I will keep them as spares when I change to 45s
    Aug 2015
    Leeds
    767
    Re: twin 40 jets any good?
    Ill be in the same position soon, although I have a big valve head and newmans 272 cam
    Jul 2015
    Cumbria
    77
    62
    9
    Quote Originally Posted by marshyboy2002 View Post
    Jets are
    Progression 60 f5
    Pump jet 45/35
    Main jet f16/125
    Idle jet 45/f8
    What size chokes?
    Aug 2013
    Worcester
    523
    20
    Ye didn't check that I'll look when I get back tonight
    Aug 2013
    Worcester
    523
    20
    Just found it on a photo on my phone
    Chokes are 34
    Aug 2015
    Leeds
    767
    How do I check what chokes are in mine?
    Aug 2013
    Worcester
    523
    20
    There will be a number stamped on the choke
    If u remove a trumpet/air filter u can slide the venturi out and then slide the choke out and have a look or u may be able to look inside with a torch or even a mobile phone on record if space is limited
    Aug 2015
    Leeds
    767
    Cheers I'll have alook
    Aug 2013
    Worcester
    523
    20
    Hay guys are these sizes any good before I buy some new ones the same
    9,200
    I think the 50 f5 is the choke enrichment.
    Mains look ok what about air corrector at top of main stack
    Idle I see 55f8 spoken of but I can only repeat from reading up.
    Hopefully someone with actual experience will pop in.
    Aug 2013
    Worcester
    523
    20
    All right are u saying use 50 f5 instead of 60f5
    25,099
    its been a very long while since i did anything with carbs, so im very rusty/forgetfull but, on 34 chokes i would think the mains are a tad small, and idles probably want changing from 45 f8 to 50 f9. but tbh i would recomend buying jets on the basis of my poor memory alone
    Aug 2013
    Worcester
    523
    20
    Will have a look what I can get off the net tonight
    Now the car is motd I have been out and about in it and it seem the more I'm driving the less it's hesitating although it's still there and I'm happy with how quick the car is so would I be right to change the main jets or am I'm barking up the rong tree as I'm as green as it gets with the carbs
    25,099
    if the problem is only a tiny throttle openings, the the issue will be the idles
    Aug 2013
    Worcester
    523
    20
    Cheers graham
    9,200
    Have you checked the accel pump jets arnt blocked ? Look into carb and snap throttle open, you should see 4 squirts one in each
    Mar 2012
    2,118
    Transition has all to do about idle jet, progression holes, position of the throttle plate and model throttle plate. So it's almost impossible to give correct advice unless the carb is a well know model. Sadly the best know model for 40 and 45 are the new ones. There is mainly only one 40 mm DCOE and unfortunately a very poor build carburetor. I strip them to the bottom, build back up as it should and ALWAY have to make mods to the prog. holes, throttle plate angle or any other mod to make it work correct.
    This is probably the carb all others will use as a reference when they give you idle jet advice (yes you can make them run as it comes out of the Weber box but many points will be very to extreme poor tuned). It will only run. If this is a race or track day car it's OK but for a road car, not so sure, they run a lot in this transition position. But what if the carb in front of you is NOT the new Weber. Let say an old Alfa or any of the few hundred different models they have ever build. Total different story. Very difficult to give advice.
    Most 40 DCOE share the same main circuit. Easier to give a basic jetting. I would also start with a richer main jet and work down worth until it"s correct. But what size is your air jet?
    Aug 2013
    Worcester
    523
    20
    Alladdin I'll try and catch that on camera to c now
    Onyd I'm not sure I'll strip one Down shortly and report back
  19. #19
    Aug 2013
    Worcester
    523
    20
    Alladdin Defo spraying fuel from all 4 bud
  20. #20
    Aug 2013
    Worcester
    523
    20
    Is the air jet at the top of the emulsion tube if so they are 160
  21. #21
    9,200
    That's the one
    I have a set of 40s I am cleaning now with smaller ones than 160 but I think drilled out
    I have got some micro drills off the bay to check them.
    180 seem commonly recommended.
    I managed to pick up some 30 chokes cheap too as its for a std pinto
  22. #22
    Aug 2013
    Worcester
    523
    20
    What mm are we talking bud
  23. #23
    9,200
    A 150 jet is 1.5mm
    180 1.8 etc
  24. #24
    Aug 2013
    Worcester
    523
    20
    Nice one bud
  25. #25
    Aug 2013
    Worcester
    523
    20
    New idles and air jets on order although I did drill the old ones and it throttled reasonable well it would not tick over and the fumes was unbearable will post how the new ones go
  26. #26
    Aug 2013
    Worcester
    523
    20
    Well I have put 50f9 idles and 180 air jets in today and what a difference the car is running a lot better although every now and again if I'm staying at lowish revs I still get that one cheeky little pop butt it's a hell of a difference driving it now
    And driving it out on the public road of course I drove sensibly cough cough
  27. #27
    9,200
    Is it a std engine ? Just curious , sorry if I missed it previously
  28. #28
    3,641
    Air correctors won't do much to low speed running, their size depends on what main jet you use, tune low end first, get idle jet transition to main sorted first then fine tune Afr by adjusting the corrector size, a 140-145 main jet with a 180 corrector should be close, 40 pump jets, and a 50 f8 or 9 should work fine until you get it on the dyno
  29. #29
    Aug 2013
    Worcester
    523
    20
    Standard pinto block with ported and polished head and a piper cam 285 I think
  30. #30
    Aug 2013
    Worcester
    523
    20
    Will get to a dyno in the new year hopefully for the man in the no to do his stuff ��
  31. #31
    3,641
    Best way, even when you think you've got it pretty close you can still be far off when you hook up an AFR meter and do some runs. I usually jet my engines on the rich side then get them on the dyno.
  32. #32
    Aug 2015
    Leeds
    767
    Mine ended up with 45f8 idle and 140 main with 180 air correctors with 32mm chokes I hink
