Hi
I've been looking around found some info but not enough so heres a run down of what i want an xe into a capri could someone tell me whats involved.
First of all i should be able to get the dis pack ecu & loom from a later xe engine but the engine i might be getting is an earlier non dis pack engine are there any differences in cams & head castings?.
I gather i'll need a blanking plate for the dizzy hole.
What sort of exhaust manifold should i looking for or is it a custom job?
On actually fitting the engine, do you use the manta gear box, spiquit bearing sp? astra clutch etc what sort of prop & diff should i be looking bolt up?
pray:
