Results 1 to 8 of 8
Thread: Zx6r engine
    Aug 2012
    lampeter
    284
    Zx6r engine
    Hi I got a zx6r engine in the back of a gokart my mate smashed it petty bad and naw it won't start I think the engine is older type with carbs not injection. I get nothing if doesn't swing over or no spark or the pump doesn't work the battery is good I was wondering if there's a cut off switch of sum kind
    25,099
    Re: Zx6r engine
    you got whats maybe a carb'd bike engine in a go kart, which could be wired and plumbed in a zillion different ways so i'm not sure how you expect any of us to know!
    Aug 2012
    lampeter
    284
    Re: Zx6r engine
    Is there a cut off on the engine or not you get them on cars were it cuts every thing off when you have a bump my old Sierra had one in the boot that cut out the fuel pump
    25,099
    Re: Zx6r engine
    the engine itself would not of had one, whether the bikes wiring loom had one, and whether it has been fitted to you kart is another matter
    Jan 2011
    clacton essex
    1,731
    70
    Re: Zx6r engine
    Are you getting power to the starter relay?
    Are you getting power out from the relay after try a crank it?
    Does the relay have a fuse on it.?
    Do the coils get live when ign on
    Aug 2012
    lampeter
    284
    Re: Zx6r engine
    I'm waiting on a new starter relay I get power to there and the fuse is ok I briged the relay and it swings over but no spark and pump not kicking in. Will the relay to the starter stop the spark I've also order new pump relay I put a direct live to the pump and it works
    Jan 2011
    clacton essex
    1,731
    70
    Re: Zx6r engine
    Sounds like you have lost the ignition, on the starter relay,is there any other wires?
    Jul 2009
    south staffs
    433
    16
    Re: Zx6r engine
    Just seen this post and , if it's zx636 iti has a ignition/ immobiliser module inside the spar on the bike. try making sure you have this.
    Hope this helps
