Results 1 to 4 of 4
Thread: P8 problem with Ostrich and Tuner Pro
    Nov 2015
    France
    Hello,
    I'm french and I am the happy owner of Escort Cosworth equipped with a P8 Magnetti Marelli ECU.
    I would like to work on the ingition and injection map with Tuner Pro RT and Ostrich Emulator 2.0 to have a good configuration for my engine.
    Unfortunately, I meet a problem in in emulation mode:
    - If I put in my ECU an Eprom Stage 2 which I wrote previously, the car starts and runs.
    - If I bring in the same file on Ostrich with Tuner Pro RT, the car leaves with difficulty on 1 only cylinder.
    - If I get back another PC with another Ostrich and another version of Tuner Pro RT: the same problem as this above: the automobile leaves on a single cylinder.
    - And both Ostrich work on other vehicles,
    - And with another P8 ECU, same report.
    I compared the 2 files with WIn OLS :it's the same and checksum comparaison is ok.
    But during the test of starting up, it is similar.
    I tried to look on which cylinder the car turned and I think that it is random because by disconnecting injectors 1 by1 , it continues to turn on a dough by feeling the gasoline.
    As if sparks in the ignition were missing.
    I know that with L6 and L8 on Sierra Cosworth, these operations were realized with no problem at all.
    I don't understand what's happening.
    Thanks to your help.
    Nov 2015
    France
    Re: P8 problem with Ostrich and Tuner Pro
    I have finally found my problem.
    I have starting the car by connecting Ostrich to my computer and Tuner Pro opened and all is ok.
    And as soon as I disconnect the computer even with the "bin" inside, the problem is present again.
    It's the first time I have this case because on others cars, the Osctrich runs perfectly without connexion with Tune Pro.
    I word with the XDF which I download on Tuner Pro web site.
    If you have a XDF more complet, i'm agree to use it.
    Thank you to your help.
    Aug 2016
    Mol, Belgium
    9
    Juju,
    I'm busy to generate WinOls full mappack.
    Can you post map adresses for the IAW48/P8 ?
    regards,
    -Kai-
    Jun 2012
    Slovakia
    I have all you want write a mail janos(at)wi-telecom(at)sk
