Results 1 to 21 of 21
Thread: fabricated alloy sump for xe
    Sep 2004
    Ireland
    354
    18
    hi i have an alloy fabricated alloy sump for an xe into an escort with 0 deg bellhousing.185 pounds plus post.this is a copy of the steel type but this comes with a recess for the steering rack so no need for lowered rack mounts.sorry for pic quality and a baffle has been fitted since.more of these will be available next week.
    Plymouth
    899
    Re: fabricated alloy sump for xe
    thats quite a recess at front of the sump to trap oil and prevent it running back to pick up point
    Sep 2004
    Ireland
    354
    18
    its only 10mm into the sump to allow for this the bowl of the sump is 7 mm deeper so the capacity of the bowl will always be 4.5lts with a total fill up of 4.75 liters which allows for 250ml of oil thats in the front section.hope this clears up any concerns.cheers mick.btw i run one of these sumps in my own red top engined mk1 putting out 215hp for the last year with no problems what so ever.the upside of the recess is i can use a wcxm with std height steering rack and therefore maintain correct geomerty and avoid bump steer issues which i had with the previous steel sump because i had to space the crossmember 10mm lower to clear the rack.
    Sep 2004
    Ireland
    354
    18
    sold 3 more will be ready next week.
    Dec 2009
    Newtownards, County Down, Northern Ireland
    86
    Could you make one for a Saab b204 and if so how much?
    East Sussex
    58
    5,023
    Have you tried one with an exhaust manifold fitted? When I made mine I had to make the exhaust side wing a lot smaller than the other side. I also baffled the wings to stop side to side movement.
    Sep 2004
    Ireland
    354
    18
    yes mine is fitted with an ashley exaust manifold and i can still get my thumb between it and the sump.with regards the saab sump i assume its the same type block as an xe is it going to be in rwd install and excuse my ignorance is it turbo need to know for oil return pipe etc.
    Oct 2015
    Suffolk
    30
    How thick is the aluminium that you use?
    Sep 2004
    Ireland
    354
    18
    4mm
    Dec 2009
    86
    Saab b204, totally different from a XE, yeap going into a MK2 escort so RWD, turbo set up, also needs a dipstick tube fitted, it should be fitted in the car January so could supy exact dimensions then. Will
    Sep 2004
    Ireland
    354
    18
    ya done a bit of searching on the b204 after a bit of checking people seem to mount them with a front bowl setup and modify the pickup to suit .i think this set up would work well in an escort for rack clearance etc.anyway once you have your dimensions please get in touch cheers mick.
    Dec 2009
    86
    Would you be able to modify the original Saab sump or would you have to fabricate one from scratch?
    Sep 2004
    Ireland
    354
    18
    i could do either,sometimes its nearly easier to scratch build due to the cast alloy sump can sometimes be difficult to weld because the cast sump can become porous and contaminated but when you decide what you need and when your ready contact me via pm and we,ll exchange numbers and get the ball rolling.cheers mick.
    Sep 2004
    Ireland
    354
    18
    have 2 of these left same price as above forgot to mention these sumps have gated baffles as well.
    Sep 2004
    Ireland
    354
    18
    one left wont be making more till after xmas contact me via pm paypal is no problem.
    Dec 2017
    Portsmouth
    Looking for sump 2.0 redtop you still doing them ??
    Plymouth
    899
    Ive got a steel one, comes with baffle tray and pick up pipe, zero indtall with the wing trimmed down to fit a big simpson or tony law manifold
    Bodger bjonsa's Avatar
    Mar 2009
    Sweden
    47
    94
    Hi Mick, do u still make these oil sumps for xe??
  19. #19
    Sep 2004
    Ireland
    354
    18
    sorry i have not made one in a long time they were costing me too much to make.
  20. #20
    Jan 2017
    Sussex
    31
    9
    Do you do any for a 1600 xe??
  21. #21
    Sep 2004
    Ireland
    354
    18
    i could make one for a 16xe but it takes me up to 3 days to make one and that is not including welding gas,welding rods,electricity and the aluminium so if you really want one it would cost 400 pounds and the postage costs to send it to you.thanks mike
