Right' whats best, cheapest and can handle high power? As I need to get one soon and need some ideas.
I've been looking at paddle clutches on Ebay-trying my luck with small bids ha ha ha-no joy though.
Someone on here-may have been Fodderboy-is using a 2.3 diesel sierra clutch-says they are stronger than standard sierra plates-and cheap at motor factors too-if i cant find a cheap paddle i'll be trying one of these.
HTH's mate.
ps hows your coming on?
Morning,
I'm using a clutch plate from a 2.3D Sierra with the standard Vauxhall cover and 'flat' type flywheel. Plate cost about 30 quid from my local autofactors and is only about 2mm smaller than the Vauxhall original. Takes loads of stick and gives you a nice progressive pedal too !!
HTH,
IanM
Sorry-was Ian not Fodderboy-i knew someone was using the 2.3D one-and this sounds ideal to me too.
Has anyone got the part codes for these bits?
using calibra turbo plate with flat flywheel and cover
What gearbox do you use with the calibra clutch?Originally Posted by fodderboy
using the 1.8 manta box till i can afford something better
Change of plan for me. I'm going to be using a T5 Gearbox to Vauxhall XE. Any ideas on clutches for this setup? Anyone know any details on T5 clutches E.g. How many splines on a T5 input shaft? Size of clutches? Part numbers? Etc.
My band: http://www.myspace.com/sanswilfred
For Sale: http://www.turbosport.co.uk/showthread.php?goto=newpost&t=126514, My items for sale on E-bay,
Wanted: T5 gearbox, Tremec TKO 600, PACE XE Dry Sump, Tilton floor mount pedal box, Large BMW LSD's 3.5:1 - 5:1, 2.2-2.4ltr petrol Frontera/GM engines.
