Bit more rot removal this week
Rust eating away at the drivers side scuttle panel. the top of the door post is not so good either and needed repairing
As I am replacing the whole panel I roughly chopped the top corner away to gain access
Likewise with the passenger side bad case of rot
Passenger side door post top repaired
Top of the bulkhead flange and hinge panel badly corroded
Once the door post repairs had been done I used the plasma cutter to remove the remainder of the panel
cant beat the clean cut of the plasma when removing old panels, spot welds were removed with a belt sander
old panel removed completely
bulkhead flanges repaired both sides
