Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 161 to 200 of 203
Thread: 1972 AVO Mexico coming back from near death experience
  1. #161
    Bodger skandimike's Avatar
    Apr 2013
    Billingham
    115
    Re: 1972 AVO Mexico coming back from near death experience
    Thanks rob this is crazy when all you have to do is go round any car show and see whats out there.
    Looks like i will just have to stick to the track and shows which is a crying shame. Or the other options is to put my the mex running gear back on or just sell it,
  2. #162
    I support TS Decade Plus User
    wildo105e's Avatar
    2,816
    100
    what is the issue ? the engine or the rest of the mods ? if you take away the engine and gearbox the rest is pretty standard period mods a lot of work but as you suggest revert back to mex running gear get the paper work and then the rest is your choice Mmmmm the whole situation is crazy given you have owned the car for so long and have photo proof of the work being carried out etc.
  3. #163
    I support TS Turbosport Subscriber rallyrob's Avatar
    1,973
    78
    Quote Originally Posted by skandimike View Post
    Yeah it's complete madness. I was thinking along the same lines, just take it to shows and use it as a Trackday car. The problem with that idea is you would have to trailer it everywhere as it's not technically road legal is it..
    It's a brilliant job finished btw. Well done
  4. The Following User Says Thank You to rallyrob For This Useful Post:
  5. #164
    Apr 2013
    Billingham
    115
    Think ill just have a bit of fun with the last few track days of the year, it would have been nice to keep the numbers together i suppose if i did put it on the road i would not be able to park it without the fear of loosing it.
    Anyway a month or so to catch up with jobs around the house then begin project no 2
  6. #165
    1,973
    78
    Very nice indeed.. That an Austin Healey?
  7. #166
    Apr 2013
    Billingham
    115
    Yes. Austin healey 3000mk3 1964. Locked away for 20yrs another retirement project. I will not make the mistake with this one as all the running gear will be standard.
  8. #167
    1,973
    78
    Nice...
    Funny that, that's what the DVSA guy said he'd got that I was speaking to on Saturday, amongst a few others too.
  9. #168
    wildo105e's Avatar
    2,816
    100
    is it not possible to get the car inspected as is then you will have the paper work correct before committing ?
    Had work colleague had an austin healey 3000 dry state import that he restored.
    Remember to post up the pics
  10. #169
    1,973
    78
    is it not possible to get the car inspected as is then you will have the paper work correct before committing ? Remember to post up the pics
    That's a bloody good idea....
  11. #170
    3,518
    Question on the water rail. I have the same set up and plan on using a heater, but the heater outlet on the housing has a tapped m8 hole, threaded incase you want to blank it. But is the m8 hole large enough for enough flow if you use a heater or do you drill it out??
  12. #171
    Apr 2013
    Billingham
    115
    Its been a while guys but since my last post I have taken the Mex to TTS Performance onto the dyno, a couple of test days and a couple of track days just when I thought it was all over I hit a few issues, firstly on the rolling road the engine did not make the power I imagined it would it only made 298 bhp instead of the 350+ I had hoped for. The main reason for this was very high inlet temp caused by a two main things
    A) being a simple schoolboy error on my part being the fact I had put a pressure cap on the radiator instead of non pressure thus not venting into the header from the top of the rad.
    B) air intake was beside the engine so the ambient air temp was too high. I knew this at the time but as the engine bay is so tight it was difficult to draw air from the front.
    So it was back home and do a few mods, Plan a route for the cold air intake meant a bit of cutting about so out came the Engine to make a bit of room so I could cut a hole in the inner wing and pick up cold air through a vent under the o\s bumper
    I used flexi pipe for this but may go for fabricated tube later.
    The next issue I had was excessive oil venting into the catch tank. This was caused because I fitted a billet breather instead of the original manufacturer’s breather. The reason I did this was because of the small valve and outlet on the original one’ big mistake as the billet unit had next to no oil /Vapour separation. So I decided to modify the original by removing the valve and welding in a Male Adapter this worked great and sorted the problem.
    The photo above shows the billet breather next to the original, looked good and gave more space when fitted but was useless.
    That was two of the issues from the dyno day sorted but while the engine was out I decided to fit some kent cams and have the manifold ceramic coated.
  13. #172
    wildo105e's Avatar
    2,816
    100
    Lol it would be rude not to, never finished these cars.
  14. #173
    Apr 2013
    Billingham
    115
    never a truer word spoken WILDO
    That was is engine back in and it was ready for the first shakedown
    Picture of the engine bay now showing the ceramic manifold. you may see a difference from an earlier photo that the carbon hydrographic dipped rocker cover has gone and back to crinkle finish, although it did look good unfortunately it didn't stand up to the heat
    now ready to see how it actually drives two test days and a track day at Teesside Autodrome then onto Croft for a track day
  15. #174
    Apr 2013
    Billingham
    115
    This was nearly the last of the track for this year another issue was quickly highlighted at Croft , because of its so much bigger than Teesside I found that I ran of gearing quickly, so decided to change the CWP . I had fitted a 5.1 / 1 so I changed it to 4.1 /1 , I gave it another go and there was great improvement . I now think its the driver now rather than the car.
  16. #175
    Feb 2011
    Caernarfon,North Wales
    152
    28
    This car looks awsome!!! Fantastic work gone into the build.
    Really hope you get logbook issues sorted out so she can be used on the road.
    Look foward to seeing it somewhere next year mate....well done!! 👊
  17. The Following User Says Thank You to 123-lorrydriver For This Useful Post:
  18. #176
    Apr 2013
    Billingham
    115
    That time of year again, you are snug for the winter and I promise not to leave you another 40years like I did last time
  19. #177
    Apr 2018
    derbyshire
    31
    15
    Just picked up on this one and I have to say what a cracking car and a credit to you fella.��
  20. The Following User Says Thank You to mark bates For This Useful Post:
  21. #178
    Jan 2005
    up north
    650
    33
    what a top quality machine you have built,hope the reg issue gets sorted then you can really use it
  22. The Following User Says Thank You to turbospud For This Useful Post:
  23. #179
    Dec 2018
    Essex
    36
    What an awesome build! thats madness that it cant be put back on the road, really hope you get it sorted.
  24. #180
    Mar 2016
    North Wales
    150
    9
    What a stunning motor, such attention to detail, it’s a credit to you and your work quality.
    Did the Zetec really make that much power from just the S/C?
    On another note, because your not going down the road registration route because of bureaucracy, there’s nothing stopping you putting your historic regs plates on if your only using on track days
  25. #181
    Apr 2013
    Billingham
    115
    Quote Originally Posted by waverunner View Post
    Many thanks for your comments, im hoping to get a run on the dyno shortly to see what i have ended up with, i was told that the standard crate engine should have been ok up to the 300bhp with standard rods and pistonsbut as i wanted a bit more i upgraded the rods and lowered the comp with 9/1 pistons, fitted the single 70mm jenvey throttle body , 630cc injectors , kent fast road sports cam and ofcourse the supercharger. I do hope i get between the 350/400 bhp.
    If not im just going to live with it,
    Maybe
  26. #182
    Apr 2013
    Billingham
    115
    That is it spring has sprung and time to get the old girl out. What better way to start the year than a feature in RetroFord mag April edition
  27. #183
    wildo105e's Avatar
    2,816
    100
    Well deserved
  28. The Following User Says Thank You to wildo105e For This Useful Post:
  29. #184
    Apr 2013
    Billingham
    115
    I know i said it was all over BUT IS IT EVER.
    New bit just arrived and getting ready to have a go at installing tomorrow. Geartronics paddle shift , flat changing with auto throttle blip etc.
    I,ll keep updating with some photos in the coming days
  30. #185
    wildo105e's Avatar
    2,816
    100
    I was watching an interesting car build on you tube were they used a fly by wires throttle body, got me thinking about throttle blips etc. They used a BRZ throttle pedal
  31. #186
    Apr 2013
    Billingham
    115
    I,m using an inline throttle blip with mine it fits in nicley with my setup. Installation just about complete , commissioning and set up booked for friday looking forward o seeing it come together.
  32. #187
    Jul 2016
    Melbourne, Australia
    25
    I was wondering simmilar, why didnt you just use a DBW throttle and integrated paddle shift system.
    With DBW, the ECU can do engine speed matching on downshit, not just kick the throttle. It can also time the actuator, blip and cut events together for a smooth up and down shift.
    I suspect it would also have been cheaper than that throttle setup and the geartronics system.
  33. #188
    wildo105e's Avatar
    2,816
    100
    Will be expecting a full report
  34. The Following User Says Thank You to wildo105e For This Useful Post:
  35. #189
    Apr 2013
    Billingham
    115
    Just about finished only track testing left to do tomorrow. �� looking good though performed well on the rollers car
  36. #190
    Apr 2019
    Isle of lewis
    26
    21
  37. The Following User Says Thank You to T22JFF For This Useful Post:
  38. #191
    Mechanic DANGERDAVE80's Avatar
    Jul 2008
    Edinburgh, United Kingdom, United Kingdom
    823
    What a stunning build mate, well done!
  39. The Following User Says Thank You to DANGERDAVE80 For This Useful Post:
  40. #192
    Norway
    35
    10
    Nice build 😎 Expensive engine 😬💵
  41. #193
    Apr 2013
    Billingham
    115
    CHRISTMAS COME EARLY
    Today just cant get any better,
    after 20mths since the forms went in my V5 has finally arrived on the doormat. My Mex is finally reunited with itsoriginal documentation and number plate.
  42. #194
    1,973
    78
    Well done.. How the bloody hell did you manage that then...?
    What did you have to supply them with?
  43. The Following User Says Thank You to rallyrob For This Useful Post:
  44. #195
    Feb 2011
    152
    28
    Fantastic result m8....Christmas come early indeed. Love this build. Hope to see it somewhere next year.
    Big congratulations pal 👏👏
  45. The Following User Says Thank You to 123-lorrydriver For This Useful Post:
  46. #196
    23,906
    236
    fantastic, well done
  47. The Following User Says Thank You to Graham For This Useful Post:
  48. #197
    Apr 2013
    Billingham
    115
    RallyRob
    Had to have the car inspected to verify it was the original type 49 shell , and supply mountain of photos and original documentation.
    Got there in the end though
  49. #198
    Feb 2011
    152
    28
    I'm running 18 silvertop in mk1 escort. I thought the same thing and questioned the outlet. However I fitted the heater pipes to the rail and the heater worked great. I struggle to get engine up to temp tho so sure the heater would be much more efficient if I could. Either need to partially cover the rad and/or fit a higher thermostat.
    Suggestions??
  50. #199
    wildo105e's Avatar
    2,816
    100
    after 20mths since the forms went in my V5 has finally arrived on the doormat. My Mex is finally reunited with its original documentation and number plate.
    Brilliant result, just goes to show sometimes sticking with it pays off. Icing on the cake.
  51. #200
    1,973
    78
    Great news. And they never questioned the fact that your original type 49 shell had new floors, arches, transmission tunnel, front and rear suspension mounts modified plus the rest of it.
    So it can be done then, who was it inspected by, dvsa themselves or just a trusty mot guy?
    So they kind of made a mockery of their own regulations then.
    So I'm also assuming that as it's technically back on it's original plate it is now both tax (well historic tax anyway) and mot exempt?
    Sounds like there's hope for the rest of us yet then...
