Results 1 to 23 of 23
Thread: cosworth yb coil on plug conversion
    Jan 2005
    up north
    670
    as i was now on my 3rd coilpack failure,dont know why but they dont last long even using original beru version, i decided to see how easy it would be to fit coil on plug to eliminate the misfires and bring it more up to date,every modern high performance petrol engine runs these now.
    clint on here does a nifty conversion with extended plug tops so you can run denso motorbike cops and use the insulator with the rubber extended,without the need for cam cover mods works great, but the plugs needed for these cops have to be threaded and that leaves fords 071c as the only plug suitable
    now these plugs are utter shite you have to buy about 16 to get 4 that will actually work,when you take the duds back to the ford dealer and other suppliers[surly they all cant be duds] they will tell you that you fitted them wrongyeah i managed to put them in upside down just as well there cheap
    with the cop conversion working great it was just the plugs that let it down,so much so that i refitted a new coilpack and a set of these ngk iridiums, now these are the danglies,seems to run better straight away
    now works perfectly but only a matter of time before the coilpack fecks up again so i thought i will get the ngk with threaded tops and refit the copsshould be the best of both worlds, only thing is these ngk are not available in 16mm plug with threaded top to fit a yb,phone call to ngk technical and the helpfull chappie said the one im looking for size wise and threaded top is only avaliable in 21mm
    so bought a set and decided to make them fit
    as its boxing day and im bored, whipped the cam cover off and up to geordies to use his milling machine,took 6mm off the plug towers and machined the plug hole out to 26mm
    also machined down a 21mm plug socket to 25.5mm so it will go through the plug hole
    the head where the plug sits also needs a bit machined from it to square up the sides as most heads are not equal in this area,a 21mm plug is a lot bigger diameter and will leave no room to get a plug socket in,thankfully i had done it to this head when i modified it.
    the brass extenders are now no longer needed with the cam cover modified, and the cops can fit direct to the ngk plug with the insulator fully home.
    now wired up and ready for the rolling road setup session
    big thanks to clint from bhp and the ngk technical man without whom none of this would have been possible
  2. The Following User Says Thank You to turbospud For This Useful Post:
  3. #2
    Mar 2008
    west bromwich
    1,861
    Re: cosworth yb coil on plug conversion
    Never had a misfire with 701s son , I like your conversion but , the coil and Beru leads work fine for me , but good on ya , doing on Boxing Day , just to get away from the turkey !
    Jan 2005
    up north
    670
    either im unlucky dad or you have been lucky so far,i have a few spare plugs and coilpacks if you need them, complete with built in misfires too
  5. #4
    Mar 2008
    west bromwich
    1,861
    Lol . Iam lucky if your are my son!
  6. #5
    Mar 2008
    west bromwich
    1,861
    The way I look at it , is if you spray petrol at flame you get a fantastic flame (coil) throw a bucket at it and the flame goes out ( coil pack ) that's by someone who works with cossy so everyday
  7. #6
    May 2004
    Norn Iron
    1,141
    There are loads of plugs either Denso or NGK available with screw tops, definitely no need to go to 21mm stuff.
    eg this is a pretty cold plug ( equivalent to NGK 9 ), iridium and removable tip
    http://www.sparkplugs.co.uk/denso-ir...park-plug-ik27
    I'd be more concerned as to why you're eating coilpacks though. What coil were you using and how were you firing it ?
  8. #7
    Jan 2005
    up north
    670
    steve,thanks,your needing to get a job with ngk technical,but i suppose ngk wont recommend another manufacturer,that denso one does look like it would fit,would have saved me machining a 21mm plug socket.
    the coil pack i was using are a vauxhall/peugot type,i think there are a lot of fakes in the supply chain and even the original beru ones fail after a while,i will find the number of it.
    its fired by a motec m4 with twin channel amp,these denso stick coils are fired the same but with 2 twin channel amps in waisted spark style
  9. #8
    May 2004
    Norn Iron
    1,141
    IMO it's more likely whatever dwell time you were running them at was the problem.
    some NGK plugs will have screw tops too, those sparkplugs websites are actually fairly good to trawl through to get information from about each plug, and they do seem to have good pictures of the actual plug they're talking about.
    Denso make great plugs though, I'd have no issue running them vs NGK, and I do at the minute on my own car.
  10. #9
    3,237
    Think yourself luck to actually have a plug choice...... us Zetec owners get one type and it ain't a threaded top! Has a damn taper thread hence the one of one status! Agree with Steve - dwell time is deffo a likely cause as coil packs are mostly bulletproof - 3.0mS is a usual max. number.
  11. #10
    May 2004
    Norn Iron
    1,141
    Yank engines seem to favour taper seats...no idea why when washers are more common throughout the rest of the world
    Or is it a taper elsewhere ?
    Even the LS normally takes taper seat plugs, but normal washer plugs fit and work perfectly anyway.
  12. #11
    Apr 2008
    Hornchurch
    117
    14
    Ive just bout a Link ECU and would like to go this route,
    Just to confirm what denso coil packs are you using? 129700-4800's? (GSXR- 600)
    And you need to bore the plug holes to 26mm to fit these? (Decking them 6mm being an option to not need adapters)
    Have you had any issues with this setup at all? heard the yaris style ones are not as good and can have problems. Are you running wasted spark?
  13. #12
    Jan 2005
    up north
    670
    i think they are honda fit ones,clint at bhp has them,
    yip bored and decked,they will fit with unmodified cover but needs extender and cut down cop seal, and its wasted spark with 2 amps
  14. #13
    Clint's Avatar
    Jul 2001
    925,879
    The link does not support direct firing of coils, use Honda K20 intelligent coils as they almost bolt in and the link will fire them directly, we have the connectors in stock
  15. #14
    Clint's Avatar
    Jul 2001
    925,879
  16. #15
    Clint's Avatar
    Jul 2001
    925,879
  17. #16
    Apr 2008
    Hornchurch
    117
    14
    Hello, i bought my ECU off you a few weeks ago - do you have a shop front that i could visit and have a chat? I need to get pretty much all my loom plugs and supplies so i can hopefully get it built over xmas
    Are the K20 coils okay to be used with wasted spark ?
    cheers
  18. #17
    Clint's Avatar
    Jul 2001
    925,879
    We do right near brands BUT although its open I am off recovering at the moment, feel free to add me on facebook https://www.facebook.com/gaskin
    What ECU did you buy ? They are fine for wasted spark but if you brought a link then you can run them individually and save a lot of plug wear.
  19. #18
    Apr 2008
    Hornchurch
    117
    14
    Oh fair enough! Ive sent you a friend request
    I got the xtreme, will that be able to use the standard distributor pickup? rather than a cam sensor ?
  20. #19
    Clint's Avatar
    Jul 2001
    925,879
    Yes all standard pickups, just select RS500 in the trigger selection.
    The extreme has 8 ignition outputs, you need to use the 4 on the A loom you can use the others for other things.
  21. #20
    Jun 2014
    Malta
    12
    I am currently in the process of going COP on my yb, I don't know what plug to run.
    On my Cortina i used to run c57c, but they started to fail at around 25psi.
    Later started to use motorcraft 071c , which are great, I don't know if i can still use them on the K20 COP.
    Any help?
    Warren
    Malta
  22. #21
    May 2004
    Norn Iron
    1,141
    NGK or Denso ! I wouldnt use Champion in anything.
  23. #22
    Jun 2014
    Malta
    12
    Hi Stevieturbo,
    Honda uses IK22 denso,
    Should i use them or go for IK24 for 350bhp mark.
    Regards
  24. #23
    Clint's Avatar
    Jul 2001
    925,879
