can this injection system be tuned ???????????????????
Yes
does it make a lot of difference clint what sort of power can be gained ??? the system i'm thinking about is the same as the older v8 bmw's bosch kjet cheers m8
Its airflow based, so when you hit its limit then you can mondify it to give more, until you reach its limit and AFR starts to drop leave it alone
loverly i'll be round to have it done then clint when/if i get the car
