Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 40 of 194
Thread: Rwd fiesta
    Bodger scoobymike's Avatar
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Hi all. Just in the process to start building a mk2 fiesta converting To rwd.
    Gona be using gp4 escort suspension on capri front crossmember, engine not sure as yet . rx8 6speed gearbox coupled to either atlas or sierra cosworth rear beam.
    I know it's a lot of work. But have converted escorts to rwd before. And I have always wanted to do fiesta.
    My only question is.
    Front anti roll bar or compression struts. Like the idea of comp struts. But would it handle better with roll bar. It's only c
    Gonna be road use.
    Any info will be taken on board. Thanks all mike
    Sep 2004
    Ireland
    354
    18
    Re: Rwd fiesta
    how about both comp struts and anti roll bar on drop links.
    Oct 2014
    south wales
    62
    176
    Hi mick32. Have not had any experience of compression struts. Only ever used rollbars . By upping roll bar diameter. Not sure about the handling. Thanks for ur ideas tho. Mike
    Sep 2004
    Ireland
    354
    18
    Re: Rwd fiesta
    you could also adapt an escort tension strut kit and they come with an anti roll bar kit as well i use this setup on my mk1 escort with bilstein struts 300/100 inserts and 250lb springs and it handles very well.but if you went with either comp or tension you have the provision to adjust castor angle quite easily. cheers mick
    Oct 2014
    south wales
    62
    176
    Hi mick32. Thanks for ur idea. Engine wise I'm thinking silvertop zetec 2.0. Running either 45 webbers or bike carbs. Drive thru rx8 gearbox. What people think on this ideas please. Mike
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Slight change of plans. Just bought a mk6 fiesta to convert to RWD,
    Her is a question for the brainy ones out there.
    Gonna run sierra 4x4 rear end. And coilovers
    Front is gp4 coilover struts and tension bars
    My question is how much castor can i build into the set up. Wrc cars run large amounts of castor
    The car is gonna be fast road / track .
    I have built a few rwd conversions but kept everything standard setup. Camber and castor.
    Oct 2015
    Essex
    347
    33
    Rwd fiesta
    How muc caster ard u after more than 5deg only if u Hav hydraulic power steering for lots self centering
    Oct 2014
    south wales
    62
    176
    Hi Ianbavs. Please can you explain more. As like I said built a few rwd, but have always kept to standard settings.
    Sent from my SM-T560 using Tapatalk
    Oct 2015
    Essex
    347
    33
    Rwd fiesta
    Are u gonna run power steering what offset wheels u running ? More caster will make the steering wheel return to centre faster for drifting etc
    U may getaway with 2-3deg on my escort I need prob 5deg as have 8 1/4 wide wheels 0 offset and power steering
    Oct 2014
    south wales
    62
    176
    Thanks for info. It's gona have sierra front end. So I could put power steering on her. As for rims not sure what yet just know I want it on 17s. Was gona wait till it's built. Then try different wheels till I find the one I like. So let me get it straight. If I run to much castor. She will straighten up quicker. Would that be all. Or is there any negatives to that. Cheers mike
    Oct 2015
    Essex
    347
    33
    Rwd fiesta
    U may get some lifting of the front end at full lock but I know mercs n bmw run loads caster but think that's helping Ackerman angle when doin tight turns maybe
    Not sure on modern cars 🤓
    Ask some kitcar builders on what they've use if it's Sierra based kit car :-)
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    So the modification begins. Click image for larger version Name:	uploadfromtaptalk1462043552836.jpg Views:	741 Size:	100.2 KB ID:	78398 Click image for larger version Name:	uploadfromtaptalk1462043571646.jpg Views:	740 Size:	103.1 KB ID:	78399
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Quote Originally Posted by scoobymike View Post
    So the modification begins. Attachment 78398 Attachment 78399
    Click image for larger version Name:	uploadfromtaptalk1462043625656.jpg Views:	725 Size:	84.5 KB ID:	78400
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Fitted floflex bushes to rear beam today. Slowly getting sorted Click image for larger version Name:	uploadfromtaptalk1463242904464.jpg Views:	692 Size:	145.7 KB ID:	78578
    Oct 2011
    Antarctica
    163
    Re: Rwd fiesta
    My mates got some conversion kits made for rx8 gearboxes to vw turbo engines. ..... Easy 400 brake and reliable..... And cheap to source
    Oct 2015
    Essex
    347
    33
    Rwd fiesta
    Can rx8 gearboxes take 400 bhp ?
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Quote Originally Posted by tkracing View Post
    Thanks tkracing.
    But im gona be running ford engine. Either st170 or zetec on bike carbs. Cheers for info anyway.
    Aug 2015
    Leeds
    767
    Re: Rwd fiesta
    Thanks tkracing.
    Speak to freddy686868 on here, he's doing bits with the rx8 boxes and adaptors
  19. #19
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Advise wanted if poss.
    I'm in the process of converting a mk6 fiesta to rwd. Using a sierra rear end as my base. It will be running cozzy brakes and lsd diff.
    Running Gaz coilovers. With 2.1/4 springs. I'm thinking of 180 lbs springs. Any ideas on the poundage, or am I correct in my thinking of 180.
    Cheers mike
  20. #20
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Look. Strengthened and shot blasted rear arms ready for painting
    Click image for larger version Name:	uploadfromtaptalk1464983795797.jpg Views:	642 Size:	121.0 KB ID:	78726
  21. #21
    Apr 2012
    glasgow
    500
    17
    Re: Rwd fiesta
    Looks good mate looking forward to seeing the rest of this build
    Keep her lit
  22. #22
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Hi cosworth 4 door.
    Yea me to. I'm still in the process of buying stuff for the conversion at mo. As I got to finish tr8 rally car for customer first to have garage space to carry out the build. I'm in no rush to built it . Wana do it right. Thanks mike
  23. #23
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Click image for larger version Name:	uploadfromtaptalk1465508885103.jpg Views:	625 Size:	63.0 KB ID:	78783Click image for larger version Name:	uploadfromtaptalk1465508892808.jpg Views:	623 Size:	68.8 KB ID:	78784
    More bits turned up. Front sierra crossmember. Like new.
    And rear hubs and discs off sierra. Slowly getting there.
  24. #24
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Few more new bits
  25. #25
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Click image for larger version Name:	uploadfromtaptalk1471105512211.jpg Views:	555 Size:	92.1 KB ID:	79170
    Been playing with dimpling my rear discs. With 8mm end mill. Looks good. Only time will tell.
  26. #26
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    [IMG]http://uploads.tapatalk-cdn.com/20161015/aa0e08d0d30161db6b686937bf7593ee.jpg[/IMG
    Nice new cosworth LSD to go on
  27. #27
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
  28. #28
    Nov 2016
    Dorset
    72
    28
    Re: Rwd fiesta
    You still working on this build Scooby ?
    Following with interest as I'm aiming to try a Focus RWD next year.
    Was thinking of an escort Mk1/2 front end though.....
    You can never have enough Ford toys
  29. #29
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Hi mash.
    Yea still buying bits at mo. Waiting to finish this for a friendClick image for larger version Name:	20160414_184038.jpg Views:	467 Size:	58.4 KB ID:	79768 . Before starting the fiesta, check out on line plenty of rwd projects to get some info. Cheers mike
  30. #30
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Small update so far. Bought a 18mm cosworth rear antiroll bar. So I thought I'd make up these to suit. Click image for larger version Name:	20170630_185608.jpg Views:	426 Size:	62.9 KB ID:	81242
    Rose jointed drop link for rear.
    And these arrived today
    Click image for larger version Name:	20170711_185951.jpg Views:	423 Size:	60.8 KB ID:	81243
  31. #31
    Oct 2014
    south wales
    62
    176
    225 lbs Coilover springs on order. Hopefully next week.
  32. #32
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    My engine
  33. #33
    3,641
    Re: Rwd fiesta
    This will be very cool.
  34. #34
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Small update. Trial mounting rear cosworth axle to feza
  35. #35
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Making up axle mounts. And scolloping out chassis to clear driveshafts
  36. #36
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Zink coated front crossmember . Engine mounts removed and Strengthend
  37. #37
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Rear diff guard
  38. #38
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Grp4 coilovers for front. Will run 330mm discs and 8 pot ksport calipers on special brackets
  39. #39
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    Mazda rx8. All painted ready to fit
  40. #40
    Oct 2014
    south wales
    62
    176
    Rwd fiesta
    St170 rebuilt. All painted and ready to go in. Once I get to build it.
