I think I'm getting there !!!
Dave
----- 3D RS Models -----... 3D RS Models ___ http://www.dmmultimedia.com ...
change the wheels to the current foci st one's and add a wrc spoiler like the power engineering foci then it would look the bizz
but i do like it a light cracking job
mrk 2 mondeo ghia saloon
17" tsw reflexs bomz kit
fast road cams/obx pulleys
drop 30mm eibach springs mongoose catback exhaust
4.1 ceramic coat exhaust manifold
custom down pipe/highflow cat
list to do :-
st bodykit 300mm disc conversion+rear disc
underdrive pulley custom management 45mm throttle bodies gasflown big valve head
comp ratio increased 11:1
looking for a mint 4x4 rouse motorsport 304r sapphire running std (260bhp) or stage 3 set up
great work Dave, I have the high res press photos and I mean high res, ie you can zoom in on the side light and see the bulb these came from Ford marketing the day before ford announced the Focus RS, these are on my home PC, drop me a mail if you want them kelvin@jkhome.gotadsl.co.uk
Cheers Kel
Nice work
Ford Focus WRC for you
Thats a totally different Focus :o
Just keeps getting better Dave
I don't have any blueprints for the new Focus ... but if anyone has any ????
Dave
i've tried drawn loadsa focuses and i think the left headlight comes a little to far toward the centre of the bonnet and makes the grille shorter also the leading edge of the front bumper: i thin that line drops too far m8.
Otherwise the car looks fantastic m8 top work, keep it up!
1380 or 1293 turbo
Drive a BMW? i'd rather Push My Mini!
actually, forget tht it looks fine from tht angle mate lol
1380 or 1293 turbo
Looks like the upper kurve of the grill is a bit too raised in the middle (just a tip=) I have a friend thatīs trying to make a monstertruck frame in some kind of 3D programme itīs extremely complicated, and itīs just straight and bent pipes. So what you are doing is just
Great model
Comments (nitpicking):
- The side indicator is too tall or not long enough.
- The sideskirt taper towards the middle of the door and it is slightly rounder.
- The headlight is slightly rounded on top and it also goes into the fender/bonnet join line.
- The edges of the grill should be more upright and that side of the headlight should follow.
Just trying to help.
Could you please try to do the Escort Cosworth next ? i will assist with measurements
1992 Escort Cosworth
nice work on the shells i could not make one like that
Thanks for the feedback guys.
I've not touched the Focus for a little while now. I'll need to dig it out and adjust things.
I have changed the Bumper lights since the last pic. Still not happy with the headlights and bonnet - might have to rip 'em off and start again.
Dave
I'm waiting for you to do the Escort Cossie
ESCORT NUTTER
Penang, Malaysia
Thanks.
To do the Escort Cossie I need some blueprints. If anybody has any ?
Or some ACCURATE plans from a model kit ?
Dave
Hi dave,
check your inbox
Cheers Kel
Mmmm ... That is VERY helpful. Thanks, Kel.
I'll have a good look at that later tonight and see how accurate they are between views.
Dave
