Hello guys
I have these MK2 RS2 struts which I'm trying to remove the original top mouts from. The problem is that I have compressed the spring, and loosend the top nut/cranked retainer, but the nut wont come off cause the piston rod turns with it! This can't be normal can it? So can anybody help me with this problem. And BTW can't tighten the nut either, just turns the piston rod the other way.
Thanks in advance, cause you guys allways comes through for me
CheeRS
The Dane
