Results 1 to 20 of 20
Thread: Zetec on type 9 - starter issues
    Jan 2004
    South Africa
    3,354
    20
    So I've been having endless issues with starter motor mesh. If fitted a 14mm spacer between the bell housing and the starter, tried another 2L pinto starter, fitted the steel spacer that goes between the engine and gearbox, still no luck.
    The starters swing making a loud grinding sound and then just seem to jam up
    2L Blacktop Zetec
    2L Zetec Flywheel
    Type 9 box and bellhousing
    Starter model : Prestolite EL25192 - 10 tooth
    Problem is I cant just go out and buy a LRS707 as the 1800 Sierra's where not sold in out country.
    Any help ? Is this the right 2L starter I'm using ?
    Jan 2011
    clacton essex
    1,731
    70
    Re: Zetec on type 9 - starter issues
    Sierra dohc starters are the same I believe
    Jan 2004
    South Africa
    3,354
    20
    Thats the problem they DOHC was also not sold here. :-(
    Feb 2005
    Norway
    438
    Some good info her for Pinto and Zetec starters, looks the same other than the spacer
    I use a version of this starter for my Zetec and 2000e gearbox in my Anglia and I like it very much
    Pinto measurements
    http://www.brise.co.uk/ckeditor/Ford%20892910AXG.pdf
    RWD Zetec measurements version
    http://www.brise.co.uk/ckeditor/Ford%20891410AXG.pdf
    Jan 2004
    South Africa
    3,354
    20
    Thanks - I've seen that and yes it doesn't make sense why my starter shouldn't work with the spacer.
    I bought the flywheel seperatly from the engine, Im wondering if all the Zetec flywheels are the same size (Outside diameter) ?
    9,200
    Are you sure it's a Zetec fw ?
    Jan 2004
    South Africa
    3,354
    20
    Asked spares salesman for a Zetec fw, bolted straight on, clutch works
    maybe I should just pull motor out and check
    9,200
    Maybe try 9 tooth starter first ?
    Jan 2004
    South Africa
    3,354
    20
    Good idea, thanks M8
    Mar 2009
    Hull
    you could of course modify the bell housing to accept the zetec starter, it has the advantage of being away from the exhaust so gives less trouble when hot.....its also not a difficult thing to do. you just need the sandwich plate from the donor car to act as a template for the bolt alignment.
    Click image for larger version Name:	sandplate.png Views:	339 Size:	114.0 KB ID:	78401
    then fix it to the bell housing as a template, cut some steel plate to shape and weld into place.....after cutting a bit away from the bell housing to suit....
    Click image for larger version Name:	bell.png Views:	340 Size:	169.5 KB ID:	78402
    here the motor in place......once done fit the bell housing to the car then refit the motor as normal......works really well one 2.0 zetec has had this mod done for over three years and 20000 miles and no issues yet......
    Click image for larger version Name:	motor.png Views:	335 Size:	162.3 KB ID:	78403
    i used the motor fitted like this to make sure everything could bolt up correctly and to make sure it all was aligned correctly....the bell housing is steel and seems to take a weld ok......
  11. The Following 2 Users Say Thank You to snowy2 For This Useful Post:
  12. #11
    Jan 2004
    South Africa
    3,354
    20
    Thats a novel approach, what intake are you using ?
  13. #12
    Mar 2009
    Hull
    i have made my own....i cut a manifold flange out of 3mm steel....by hand. it was a fair bit of effort. i then cut the injector plate from the donor manifold, got some 1mm sheet steel and folded it into a 3" X 3" tube
    Click image for larger version Name:	030641ee-6351-467e-9979-aa6f5e71c0ed_zpssuygdafa.jpg Views:	321 Size:	29.2 KB ID:	78405
    the inlet runners are new exhaust pipe at about 32mm diameter....
    Click image for larger version Name:	5b2b45e1-dfd1-40ab-a065-bf1e69cc2452_zpsqhe4ccvt.jpg Views:	321 Size:	47.0 KB ID:	78406
    I have even made myself a fuel tank from 1mm sheet steel, which will accept the standard ford fuel pump on its correct mounting....so easy to swap if it gives trouble. the tank works out at 46L or about 10 gallons.
  14. #13
    Mar 2009
    Hull
    the thing is i have a couple of CVH starters i acquired for my project.....but changed my mind as i want the exhaust side to be clear of both the alternator and the starter to help prevent trouble in use....the CVH starters are promised to another builder who doesn’t fancy modifying the bell housing the same way as my self.
  15. #14
    Jan 2004
    South Africa
    3,354
    20
    Hmm my DCOE intake would be in the way of the starter
  16. #15
    Mar 2009
    Hull
    You sure.....?
    The zetec starter is quite small and sits low ...
  17. #16
    Feb 2015
    Snowy2
    You sir are an inspiration,was going to fork out Hundreds of pounds getting a starter motor to fit my Blacktop with a type 9 gearbox/bellhousing,,,,but after seeing your bellhousing mod,for twenty quid I've ordered a plasma cut ring ( will do 2 bellhousings ) and can use the original starter motor in the original position...
    John
  18. #17
    Mar 2016
    Australia, ACT
    glad i found this, i looked at it today and had thoughts of doing similar, now im pretty happy to go ahead with it, nice off the shelf starter in Australia, i did some mocking up with the 2L pinto one i rebuilt for the motor that im replacing and it was all looking a bit of a pain, especially in regards to the sump mods im working on, thanks
  19. #18
    May 2007
    Jhb South Africa
    85
    Craig , maybe check with Clive Wilmot , I think he's done a couple of these conversions . Also check on FB there's a RWD Zetec group that's quite active.
    Dion
  20. #19
    May 2007
    Jhb South Africa
    85
    Double post . Sorry .
  21. #20
    Feb 2015
    Snowy2
    Many thanks once again,have been running my Type9 with Zetec Blacktop for quite a while and the starter motor mod is excellent...even using the original starter loom
    John ;-)
