Results 1 to 10 of 10
Thread: XE Cooling
    Aug 2005
    Southport
    61
    XE Cooling
    Just wandering what type of cooling system any of you guys are using in your mk1 or mk2 running a 2l vauxhall motor? I know there's readily available custom made alloy types for around the 300 quid mark, but was wandering if a radiator from any other car would do?
    Thanks in advance
    Mar 2004
    Barking Essex
    9,034
    262
    Re: XE Cooling
    Large header radiator fron a mk 1 twin cam or a mk1 transit or capri rad
    oil cooler...Kenlow ...jobs a good en..
    Old skool forever
    Just don`t tell the wife
    how much it really costs!
    FOSSIE's Avatar
    Oct 2004
    NEWCASTLE
    1,591
    Re: XE Cooling
    Quote Originally Posted by cossymax
    Totally agree
    You don't need to go overboard with the cooling on one of these. I used a mk1 capri rad, and had it re-cored with a more modern, more efficient core to be on the safe side. Also - i had the rad sealed up and used the GM header tank - perhaps this is uneccesary though.
    thermostatically controlled kenlowe - dead simple and works a treat.
    Aug 2005
    Southport
    61
    Re: XE Cooling
    Thanks for the help gents
    Is it not possible to use the original astra oil cooler?
    FOSSIE's Avatar
    Oct 2004
    NEWCASTLE
    1,591
    Re: XE Cooling
    yes mate, for road use with anything like the original power output it'd be OK. The more modified the engine, the more heat it'd be generating so you might want to upgrade a bit.
    Mar 2004
    Barking Essex
    9,034
    262
    Re: XE Cooling
    Agreed,As Fossie said it works a treat,As i have one on my Cortina
    Old skool forever
    Racer zoso11's Avatar
    Nov 2004
    Gibraltar
    1,425
    Re: XE Cooling
    what about after market alloy rads for rs2ks.. such as pace, pro alloy and the likes of those guys
    FOSSIE's Avatar
    Oct 2004
    NEWCASTLE
    1,591
    Re: XE Cooling
    well you can if you like... but they are expensive, and my strategy was along the lines of don't spend money where it's not needed. (i.e. the big header capri or transit rad do the job just nice)
    Anyway, copper/brass is superior as a material for making automotive rads!
    Nov 2004
    Gibraltar
    1,425
    Re: XE Cooling
    Quote Originally Posted by FOSSIE
    the guy i bought mine from has fitted a larger cored rad, im sure it says in the history from sum v6 engined ford, cortina, capri an so on
    Jan 2006
    sheffield
    Re: XE Cooling
    I used a capri 2.8i rad which i had re-cored for 80 quid.
Similar Threads
  1. Cooling system plumbing
    By Phunt101 in forum The Technical Section
    Last Post: 17-08-2005, 01:14
  2. Cooling problems
    By RChambers in forum The Technical Section
    Last Post: 30-06-2005, 22:52
  3. What cooling system do you use??
    By miikk in forum The Technical Section
    Last Post: 28-11-2004, 22:27
  4. 2.9 4x4 cooling problem
    By Dunc in forum The Technical Section
    Last Post: 11-10-2004, 20:14
  5. Cooling tips
    By RADesigns in forum The Technical Section
    Last Post: 01-08-2002, 10:16
