Mondeo Pas noise
Hi All
I friend of mine has a 20 tdci Mondeo 2009 which had noisy and heavy power steering when turning. Changed the pump for a Remy exchange unit ,Now it operates fine But the pump is noisy all the time and the groaning increases with engine speed ???
also noticed the fluid in the tank is splashing around a LOT all the time?
Do you think he's got a bad pump or the racks at fault ! The system was drained and the correct Ford spec fluid used, There nothing leaking and the belt tension,s ok
Any way to test it or advice most welcome
Thanks Paul
Re: Mondeo Pas noise
2 things to check. first is the feed pipe going into pump, check the 'o' ring on it isnt damaged. second is in the bottom of fluid reservoir is a filter, check it isnt blocked
Thanks for reply mate. Been told the filter has to be replaced along with the tank ? But will have a go at flushing it out 1st ,
Thanks again Paul
