Specs:Pictures:
- AP Racing Front brakes: 355x32 discs, 6-pot CP5555 calipers, titanium bells.
- Graham Goode Racing / AP Racing frear brake kit: 330mm slotted dics, 4-pot calipers.
- Graham Goode Racing high pressure cooling system: Aluminium header tank, aluminium radiator, swirl-pot and braided hoses.
- Graham Goode Racing 3-port oil separator with catch tank and braided hoses.
- Graham Goode Racing "Gp.A" dump valve, relocated on cold side.
- Graham Goode Racing Aluminum servo oil reservoir with braided hoses.
- Genuine RS500 intercooler (on the way in after 2 years under my bed).
- Graham Goode Racing Cone and trumpet induction kit with K&N filter.
- Graham Goode Racing quickshift.
- Stage 3: Green injectors, high-flow fuel pump, GGR chip, Ford WRC 4-layer headgasket, ARP studs, -31 actuator, motorsport plug-leads.
- Carbon/kevlar full cambelt cover.
- Wheels / tires: 8x18 ET15 Compomotive MO wheels with 225/40ZR18 Bridgestone Potenza S03 Pole position tires.
- Complete Powerflex polyurethan front and rear suspension bushing kit.
- Front and rear 3-way adjustable Öhlins coil-over dampers with remote reservoirs.
- Front and rear aluminum strut braces.
- 3 inch Mongoose stainless steel exhaust system.
- Samco silicone boost hoses with dump valve take-off on cold side.
- Morette/Cibie twin headlight conversion.
- WRC front bumper and grille.
