Engine choice in mk2 escort
What's people's thoughts on engine choice
for a mk2 escort,I do sprints etc with the car and currently using a n/a cosworth
thinking of going big power turbo or sticking to n/a with a millington
any thoughts would be good
Re: Engine choice in mk2 escort
depending on which millington you use you might find yourself in sports libre class, a series 1 millington is still based around a pinto block, but the newer alloy block ones could cause you eligability issues because the car would no longer be using the correct engine block type.
oh and on the tighter twisty stufff a big turbo motor is often slower than a well sorted n/a
How about a 2.5 Duratec, 300bhp and 240lb ft torque.
bad news in sprinting, wrong engine for the model of car, so you end up in sports libre class which is basically anything goes, but typically single seater type things with monster engines
