Results 1 to 2 of 2
Thread: Weber - Lean Idle Adjustment
    Clint's Avatar
    Jul 2001
    932,929
    Carburetor Set Up and Lean Best Idle Adjustment
    Base line Settings
    Speed Screw 1 to 11/2 turns
    Mixture Screw 2 turns
    Your settings with engine running
    Speed Screw______________
    Mixture Screw______________
    It is important to follow all linkage and lever installation instructions. The number one and two reasons for tuning errors are improper linkage installations and over tightened linkage nut, causing a binding in linkage assembly.
    CALIBRATIONS MAY VARY DUE TO REGIONAL FUELS AND STATE OF ENGINE TUNE AND PERFORMANCE. POOR RUNNING QUALITY DOES NOT MEAN A DEFECT IN THE CARBURETOR. AN ADVANTAGE OF THE WEBER CARBURETOR IS ITS EASE OF ADJUSTMENT AND TUNING.
    SET UP ADJUSTMENTS
    Start set up by confirming carb base line settings. Do not depend on the factory delivered settings. Check them before the carb is installed.
    All settings are done with choke disengaged or warmed up so that the choke is fully opened and disengaged. This is done on automatic choke carburetors by first opening the choke butterfly by hand and inserting a wood block or wedge of some kind to hold open while the linkage is cycled (linkage operated through its full movement ) to clear the choke cam. (You will hear a metallic click as the cam is released. You can check the fast Idle screw under the choke assembly to confirm that it is not in contact with the choke fast idle cam.)
    Set the Idle stop screw (speed screw see fig 1) by backing out the Idle speed screw until it is not in contact with the throttle stop lever. Cycle the linkage again to be sure that the linkage comes to close without any assistance. (Checking for linkage bind) Now bring screw back into contact with the lever and continue to open or screwing in 1 turn no more than 11/2 turns.
    Set the mixture screw (see Fig 1) by first screwing in until the screw stops, bottoms out. DO NOT FORCE OR BIND AS THIS WILL CAUSE DAMAGE TO THE SCREW AND IT’S SEAT IN THE BODY OF CARBURETOR. Back out the screw 2 full turns.
    TUNING
    BE SURE TO FOLLOW THE NEXT INSTRUCTIONS IN THE PROPER SEQUENCE, DEVIATION WILL CAUSE THE CARBURETOR TO NOT FUNCTION TO ITS IDEAL SPECIFICATIONS AND MAY NOT PROVIDE THE PERFORMANCE AND FUEL ECONOMY AS DESIGNED.
    Start the engine, the engine will run very slowly more like a tractor. As long as the engine stays running idle speed is not important at this point.
    The first thing to do is not set up the idle speed, but to set the Idle mixture screw to lean best idle setting. First, turn in the mixture screw until the engine dies or runs worse, then back out the screw (recommend turning ¼ to ½ turn at a time). The engine should pick up speed and begin to smooth out. Back out ½ turn more, or until the screw does nothing or runs worse then turn back to the point where it ran its best.
    Use your ear, not a scope or tuning instruments at this point. You want to tune the engine by sound. Adjust to best, fastest and smoothest running point.
    Now that the mixture screw is at its best running location, you can adjust the Idle speed the screw. The screw will be sensitive and should only take ¼ to ½ turns to achieve the idle speed you like.
    Check and set idle to your driving preference. Put the car in gear and apply slight load, (AC on) and set the Idle as you like it. Don’t set it too high, as this will cause causes excessive clutch and brake wear. The Idle only needs to be 7 to 900 RPM with light load or AC on.
    Recheck timing and vacuum hook ups. Recheck mixture screw to lean best idle again. If all is still best and smoothest idle then confirm and note the final settings.
    To confirm settings with the engine running. Start by screwing in the mixture screw and count the number of turns it takes to bottom out and note if the engine dies. If Idle Mixture screws are with in ½ turn of base line setting then all is well and have fun. Also check the speed screw and note how many total turns from initial contact. You may have opened (turned in) the speed screw. Your final setting should be under 2 full turns. Reset the screws (back in) to the best final settings (Per your notes) and go on a test drive and have fun. If the settings are other than described then you may want to recalibrate the Idle circuit (low speed circuit) to your engines needs. This is done by following the rule of thumb BELOW.
    Simple Rules for low speed calibration
    If the mixture screw is more than 2 1/2 turns out turns then the Idle jet is too lean (too Small). When the mixture screw is less than 11/2 then the Idle jet is too rich (too large). These assumptions are based on the fact that the speed screw setting is not opened more than 11/2 turns. If the speed screw has to be opened 2 or more turns then this is also an indication of a lean condition usually requiring greater change. At times it may appear to be showing signs of richness or flooding it is really a lean condition. See pictures and notes in the tech 2 article supplied in the kit instructions, view and please understand the need to keep throttle plate as near to closed as possible so as not to prematurely expose the transition holes. This is what causes the visible rich condition, and confirms the need to increase the jet size. JET KITS are available if needed.
    EXAMPLE With the speed screw set at no more than (1 1/2) turns in after contact with the stop lever; and the best idle occurring with the mixture screw set at 3 turns from bottom, indicates the need for a larger Idle jet. Achieving the best idle at under 2 turns indicates the need for a smaller idle jet.
    The secret to understanding the critical nature of the carburetor set up and the advantages of a WEBER over other carburetors is the Idle circuit. Referred to as the low speed circuit by Weber, this circuit is responsible for 80% of the driving operation. This is the reason that the Weber should give a fuel economy improvement over most factory carbs along with significant performance gains. In the worst case you should not see a significant fuel economy loss over stock, while improving HP & Drivability.
    The Weber Carburetor is a sequentially timed device to the motor like the distributor. Time taken in the setup will provide more fun later.
    Clint's Avatar
    Jul 2001
    932,929
    Re: Weber - Lean Idle Adjustment
    Addendum to Lean Best Idle Adjustments
    Notes and adjustments for IDF and DCOE Carburetors
    All adjustment procedures are the same as the progressive carbs. It is important to understand the dynamic differences of the two carb styles Progressive and Synchronous carbs Or better described as individual runner carbs.
    The progressive idles through barrel and one mixture screw hole, then transitions to a secondary barrel with an additional Idle / low speed jet. The Individual Runner carbs IDF and DCOE have individual Idle jets and mixture screws for each barrel. They also have an additional air bleed screw and lock nut. This is not used for Idle adjustment or Idle quality. The settings for this screw should be closed.
    The Main adjustments Speed and Mixture Screw for the individual runner carbs have different values than the Progressive. They tend to be ½ of those used on the progressive
    Standard IDF & DCOE Settings
    Speed screw ¼ to ½ turn in after contact with lever.
    Mixture Screw 1 turn out from seated
    Follow the same basic procedures as used with the progressive carbs with the exception that there is no choke system and no need to clear the choke cam.
    It is important to be very sure there is no throttle shaft bind or over tightened levers. This is the number one reason for most adjustment and tuning problems.
    The rules of thumb still hold true the base line settings are only the starting point. The example would be
    If your mixture screw is out more than one turn like 11/2 turns then your idle jet is too lean go up one half size on the Idle jet not main jet.
    If you mixture screw is not out one full turn something like only 1/2 turn out from seat then your Idle jet is too rich. This is all based on the important fact that your speed screws are not open more than ½ turn if they are then that is also an indication that you have a lean Idle circuit. You are cheating by opening the throttle plates and exposing additional progression holes in the transition.
    These carbs are also commonly used in pairs, this makes the synchronization important please be sure when ever balancing twin carbs to bring the high carb down to the low carburetor.
Similar Threads
  1. How To: Weber 38DGAS - Tuning
    By Clint in forum Carburettor Information
    Last Post: 31-07-2017, 19:42
  2. How To: Weber - Jetting and Tuning Downdraft and Sidedraft Carbs.
    Last Post: 05-05-2015, 14:31
  3. Zetec Escort idle tale of woe..
    By revingtosh in forum The Technical Section
    Last Post: 09-01-2006, 00:01
  4. COSWORTH, EEC4 TO WEBER MERELLI
    By 777 in forum Cosworth Installations
    Last Post: 07-04-2004, 22:06
  5. Idle speed
    By Toppy in forum General Car Banter
    Last Post: 27-02-2002, 13:04
