Guys,
Will it be wide enough if I use 7 inch wide wheels with 2 inch offset on my escort mk1? The car has wide arches and I am having doubts if the 7 inch wheels will be enough to fill the space of the wheel well.
Thanks in advance
Mac
Guys,
Thanks in advance
Mac
Really depends on the axle you're using as well as the offset of the wheels. I'm using a 52" Atlas and 8" wide ET0 wheels on mine. It will vary depending on what you've got.
I use 10" wide on mine with an English axle,
I used 8 inch with 10mm hubcentric spacers
So. The questions not been answered. Basically there would be the incorporation of either a 50" or 52" axle on a wide body Mk1 escort.
Can we base this on a 52'' Axle. If all measurements were based on a 52" axle, it would mean that the same wheel dimensions and offset could be used on a 50'' with the use of a 1" wheel spacer.
question 1. Whats the widest wheel that will fit? 7,8,9,10? ( this is for the rear end only)
Question 2. What offset (-) would be required for question 1's answer?
Question 3. i would personally not want to much wheel and rubber under the front. steering geometry has to be accounted for as well as drivability. I would not want to exceed 7" with 205s on the front. So what would be the offset for that ?
No need for photos of cars racing about with lovely wheels as it really doesn't answer anything.
Thanks guys.
On the front why don't you fit GP4 type alloy front hubs that are 10mm wider per side than std cast hubs, these can be bought to fit your std studs. That way you can use 205 tyres on the front and they should fill the arch.
On the rear if you are on a 48.5 inch english axle you can use a moderate width wheel spacer to fill the arch. The ideal wheel to use is OO offset. Sorry no photos of Mk1's to post!
