Page 2 of 2 FirstFirst 1 2
Results 41 to 64 of 64
Thread: Dekoding Chip on Pectel board for p8 ECU.
  1. #41
    Aug 2018
    Greece
    31
    Re: Dekoding Chip on Pectel board for p8 ECU.
    HI thanks for the answer. Here is a copy of that!
    Attached Files Attached Files
  2. #42
    Aug 2018
    Greece
    31
    You mean only the maps ? and how can I open them via tunerpro then ?
  3. #43
    Dec 2015
    Denmark
    Hi Panoscos
    This is the file you send, the MAP-Part are decoded, so you can use the file in Tunerpro, but if you burn a Eprom with the decoded file it will NOT WORK.
    The program are coded with a other algo, I will not use the time to find out, the map-part are the most interesting.
    Regards
    Kim Bonde
  4. #44
    Aug 2018
    Greece
    31
    Thank you very much for your help!!!
  5. #45
    Mar 2020
    Wales
    Maybe lighting an old thread but any chance if i read my pectel chip u can decode it pls
    Im looking to program another chip an dich the pectel board
  6. #46
    Dec 2015
    Denmark
    Hi Dandorst
    I Can Decode the Map-part so you can use the the mapīs in a other chip Without the Pectel protection board, or you can make thanges.
    I thing we need some more to help with the decoding of the Pectel program.
    The coding of the map's are the same for all Pectel chips, but program are more difficult.
    Regards
    Kim Bonde
  7. #47
    Jul 2016
    Spain
    12
    Quote Originally Posted by kim bonde View Post
    Hi
    The Grautec protection board from Germany is now solwed.
    There are 2 sorts of board one for L8 ( more protection ) and one for P8 ( les protection )
    I will make a demo of the decoding program later.
    Kim Bonde
    Hi Kim,
    Any info about this one?
    Thanks in advance
  8. #48
    Dec 2015
    Denmark
    Hi
    I have worked on a other coding mode from Grautec ( Germany Company, copy protection board ).
    I have olso made a program for decoding this one.
    Send a copy of the Bin-file I will decode the whole chip , so you can use is without copy protection board.
    If you want to fing out how is works, use a mulimeter , find the data bins, and find out how the are twisted pin 1 = 4 , 4 = ? , ? = ? . !!!!!!!
    Make a program who makes the file right about data-pin twisted.
    Now you can start looking for the right adress for the data .
    Adress 1,4,8,32,128,512 are used for the right adess to bee added or xor , find the adress you read from . eks adress $0 = 512 + 32 = 544. That means you
    have to go to adress $544 ( when you use a hex editor you have to transate to HEX) i the coded bin file ,to get the right data for Adress $0 in the org bin file.
    It is a combination or how you use And,Or,XOR for 1,4,8,32,128,512 together with the org adress.
    You need to have a org.bin file to compare the right adress.
    You only have to decode from adress $0 to 1023 to solve the chip. Than you start all over again .
    It can be done.
    What I now, there are 3 version of coding formula.
    Used by a known Tuner.
    Now I am working on the EVC copy protection board ( the data ben swap are the same as Grautec, but the adress are diff.)
    Regards
    Kim Bonde
  9. #49
    Feb 2021
    Switzerland
    Is it possible to decode a grautec encrypted file?
  10. #50
    Dec 2015
    Denmark
    Hi
    I have made a program for decode Grautec encrypted chip.
    there are 3 version's of what I have found out.
    Read the Eprom without the protection board , I will tray to decode , and send it back.
    Regards
    Kim Bonde
  11. #51
    Jun 2002
    Blackpool
    119
    Quote Originally Posted by Eastside View Post
    Of course it is.
    They supply a software decoder with the boards they sell
    Best Regards,
    Stu
    www.motorsport-developments.co.uk
    01253 508400 (7 lines)
  12. #52
    Feb 2021
    Switzerland
    I have read the Eprom without the board and opened the file with Tunerpro. It looks like a stage 1 Chip with a lot more boost limit and rpm cut.
    But for what is the board, if this not encrypted?
    Looks like a encryption board, with a "turbo" sticker put on.Click image for larger version Name:	2013-06-09 15.14.32.jpg Views:	283 Size:	92.4 KB ID:	86693
  13. #53
    Dec 2015
    Denmark
    Hi
    Send a copy of the Eprom
    Regards
    Kim Bonde
  14. #54
    Feb 2021
    Switzerland
  15. #55
    Dec 2015
    Denmark
    Hi
    This is a Superchip for Escort Cosworth P8 ECU.
    The protection board are for Turbo eproms ( coding are diff for nasp chip's ).
    I thing you can use chip without protection board.
    Regards
    Kim Bonde
  16. #56
    Feb 2021
    Switzerland
    Wow...very interesting.
    Why you think is this from Superchip?
    And i have think, this is a encryption board.
    What does this "Protection board"?
  17. #57
    Dec 2015
    Denmark
    Hi
    Look inside the chip at some of the first adresses $0060
    You se some letters in wrong order if you move the order you will find out.
    It says Superchip Escort
    I thing the protection board is not in use, because some off ecu have problem , when turn Ign on the ecu will not work, you have to turn Ign on again.
    The protection board are slowing the program in the chip. ( not sure about that ).
    Regards
    Kim Bonde
  18. #58
    Dec 2015
    Denmark
  19. #59
    Dec 2013
    spain
    17
    hi, coud someone, tell me what .XDF file should use with Tunerpro to see data from escorth cosworth p8 chip (chip work with 3 bar map)? please
    I use this .xdf but tunerpro values ​​don't seem correct
    P8_research_ver2.0.xdf
  20. #60
    Dec 2013
    spain
    17
    hi, could someone decode this? please
  21. #61
    Dec 2015
    Denmark
    Hi Runner
    Here are the map's decoded (only the map part )
    You can copy them into a org bin file and open in tuner Pro.
    Regards
    Kim Bonde
  22. The Following User Says Thank You to kim bonde For This Useful Post:
  23. #62
    Dec 2013
    spain
    17
    did not see your reply until now.
    Thanks KIM BONDE!!!
  24. #63
    Jun 2023
    Germany
    33
    Hi there,
    Are you still active?
    I've would really appreciate your help whit 2 Secured Files.. Evc/grautec
    Very best regards
    Martin
  25. #64
    Dec 2015
    Denmark
    Hi
    I am active.
    Tell me more about the files you want to be decoded.
    Send the eprom files read without the protection board.
    Regards
    Kim Bonde
