Page 1 of 2 1 2 LastLast
Results 1 to 40 of 64
Thread: Dekoding Chip on Pectel board for p8 ECU.
    Dec 2015
    Denmark
    Hi
    Have anybody tried to decode Superchip or Pectel chip for P8 ?
    I am working on Pectel P8.
    It looks like adress 0, 1, 2, 3 repeat from adress 0710 to 0fff.
    D0,DO,D0,DO,,,,,, are changes to CF,53,57,E7,,,,,
    The map area are more difficult
    Regards
    Kim Bonde
    Denmark
    Jun 2013
    Norge
    Re: Dekoding Chip on Pectel board for p8 ECU.
    Post your bin file then I can try to help
    Dec 2015
    Denmark
    Hi Jan300
    Here are the P8 bin files.
    Regards
    Kim Bonde
    Attached Files Attached Files
    Dec 2015
    Denmark
    Hi Some information on Pectel P8 coding. Adress 0,4,8,A have the coding formula. J have made a pascal program to copy this adress to a file. Now the hard work began. Some of then coding formula are known D0=CF, FF=3D, 00=C2. I thing D0 = CF makes 0 = C so if you have a data ending on 0, it will became C. It makes
    0=C 8=D
    1=4 9=5
    2=E A=F
    3=6 B=7
    4=8 C=9
    5=0 D=1
    6=A E=B
    7=2 F=3
    So to go from C to 4 you only turn off bit value 8. Now the value of D = F (D0 = CF)
    That ho far J have come.
    Let me hear from you
    Kim Bonde
    Dec 2015
    Denmark
    Hi
    Here are a copy of adress 0,4,8,C to a file cod-048C.bin in Pectel format.
    The file dec-048C.bin are decoded with what I thing is right for Adress 0,4,8,C.
    Adress 1,5,9,D and 2,6,A,E and 3,6,B,F are more difficult
    Regards
    Kim Bonde
    Dec 2015
    Denmark
    CODED.BINDECODED.BINHi
    Problem solved I think.
    coded.bin is Pectel P8 coded file, but it is only the Map-part from adress 0710 to 0FFF.
    decoded.bin is the Map-part decoded from adress 0710 to 0fff.
    Regards
    Kim Bonde
    Sep 2016
    UK
    Hi KIm
    Been a while I know but what are you trying to do, I might be able to assist
    Dec 2015
    Denmark
    Hi Robink
    Look at the coded.bin and decoded bin files in post 6.
    This files are from PECTEL copy protection board for P8 ecu.
    J have made a program to decode the map part.
    Regards
    Kim Bonde
    Sep 2016
    UK
    Hi
    Yes I kind of gathered that, but why, was it for interest or where you trying to modify it.
    All this kind of stuff was done 20+ Years ago and is available in some form, from several suppliers, even the boards, PAL's, chips etc.
    I Was curious as to why you were going to such lengths, presume you know exactly what each Rom chip (M***T*NE ones)is and that they are only compatible with individual boards.
    Dec 2015
    Denmark
    Hi
    It is for interest AND for have a look of the dif of the map from the suppliers of Rom.
    The Map part are the same decoding formula for all the chips I have decoded.
    The dif. are the program.
    In your first post is looks like you want to assist ??????
    Sep 2016
    UK
    Yes happy to help, What do you need
    Dec 2015
    Denmark
    Hi Robink
    Do you now the Adress for WOT in the P8 ECU ?
    Have you tried to decode GRAUTEC protection board.
    Regards
    Kim Bonde
    Sep 2016
    UK
    Hi Kim
    The WOT is a multiplier at 89DO and is a 16 byte curve mapped against RPM, it is limited by U/L and Lower limits of throttle angle which are also 16 byte curves respectively at 89E0 and 89F0. Hope that helps
    I have seen a Grautec Board but not in a P8
    Jun 2012
    Slovakia
    guys, can we have a little personal communication about this stuff? we are all working on same thing.
    thanks
    Dec 2015
    Denmark
    Hi midnigtman
    Yes we can.
    The Pectel decoding map program works.
    The Grautec coding board works the same as EVC olso from Germany, data pin 1 and 4 and 5 are twisted, use a multimeter to find out.
    The Adress pins are olso twisted, use a multimeter.
    Mar 2008
    west bromwich
    1,861
    Would love a copy of the pectel decode program
    Jul 2016
    Spain
    12
    Really nice info here!!
    Dec 2015
    Denmark
    Hi
    The Grautec protection board from Germany is now solwed.
    There are 2 sorts of board one for L8 ( more protection ) and one for P8 ( les protection )
    I will make a demo of the decoding program later.
    Kim Bonde
  19. #19
    Jan 2009
    italy
    hello can you help me find the conversion formulas Adress 1,5,9, D and 2,6, A, E and 3,6, B, F I tried but it's too difficult...
  20. #20
    Dec 2015
    Denmark
    Hi
    Do you now how to make a program (pascal,....). ?
    First you have to make a program to make 4 files , one for adress 0,4,8,C, one for adress 1,5,9,D ......
    Then you have to make a copy of a org.bin file, and a copy of a tun.bin file. ( Only the map part , start with CF,53,57,E7,CF,53,57,E7......... )
    Now you have to make a program that will compare the org.bin 1 file with tun.bin 1 file .....
    After that you can look for hex value 00 in the org.bin file and compare with tun bin.file (The adress have to match ).
    Write it on paper look for hex 01 and 02 and ....... for all 4 files ( it takes time for Me 3 month. )
    After that you can make a program that will do the job for you.
    I will NOT give away My program but I will help you . ( show me the progress when you begin )
    Regards
    Kim Bonde
  21. #21
    Jan 2009
    italy
    hello kim ... could you send me your e-mail in mp? I would just like to ask you if you think I'm on the street track .. sorry my poor English ..
  22. #22
    Tyre Kicker Mark_Lister's Avatar
    Mar 2003
    West Sussex
    Sorry to bump a thread, but is it possible to decode a p8 pectel encrypted chip? I’ve got a map on a p8 pectel board chip I run at the moment and I’d like to decode it so I can use this as a base map on a GEMs P8.
    Anyone?
  23. #23
    Dec 2015
    Denmark
    Hi
    Send a read of the Pectel chip, I will send the decode map-part back
    Regards
    Kim Bonde
  24. #24
    Mar 2003
    West Sussex
    Great, I’ll get it off the eprom and uploaded.
  25. #25
    Mar 2003
    West Sussex
  26. #26
    Dec 2015
    Denmark
    Hi
    The Decoded Map-part
    MARK.BIN
  27. The Following User Says Thank You to kim bonde For This Useful Post:
  28. #27
    Mar 2003
    West Sussex
    Awesome.
    Don't suppose you would know how to test a P8 - I think my GEMS P8 is dead - no fuel pump prime or iscv test on ignition+
    Plugging my original P8 back in (with a Pectel Board - hence the decrypt) - everything works as it should.
  29. #28
    Dec 2015
    Denmark
    Hi Mark
    Here is a org bin file for P8 escort
  30. The Following User Says Thank You to kim bonde For This Useful Post:
  31. #29
    Mar 2003
    West Sussex
    Life saver!
  32. #30
    Jun 2012
    Slovakia
    I must dissapoint you...gems ecu is not using that EEPROM for maps...if you just plug OE bin into eeprom...car wont start.
  33. #31
    Mar 2003
    West Sussex
    I know. I have 2 P8s. One GEMs one and one with a pectel board. I just wanted to put my pectel one back to standard to check that my loom was configured correctly (which it is) and the issues I have lie with the GEMs ecu - it’s not priming the pumps and pulsing the iscv (my P8 with pectel board/chip and also with a standard P8 chip in - it primes and pulses perfectly).
    So thanks to Kim, I can definitely say it’s the GEMs ecu at fault.
  34. #32
    Jun 2012
    Slovakia
    aah yes...
    who knows... if you dont want to save that gems ecu, just change that Special MCU in GEMS to standard 68HC11 for P8...put your 27C256....
    check other components on PCB (if are same as OE P8) and you have OEM P8 ecu
    there is no reason to have some "pectel" in these days....
  35. #33
    Mar 2003
    West Sussex
    I'm pretty sure it's the controller component that's not working on the gems unit
  36. #34
    Mar 2003
    West Sussex
    Just for posterity in case anyone comes to the thread - the GEMS P8 ecu uses a replacement socket mounted MCU - Motorola MC68HC811E2FN and an additional ST Microelectronics VNP5N07 mounted to the ECU case/bar. There are a few other tweaks - such as a removed components, replaced resistors and a 3 pin plug.
    Might be of interest.
    https://www.stardeluxe.co.uk/resources/ecu1.jpg
    https://www.stardeluxe.co.uk/resources/ecu2.jpg
  37. #35
    Mar 2003
    West Sussex
    That for an 8 injector unit (hence the Mosfet driver).
  38. #36
    Jun 2012
    Slovakia
    you have 2 options...
    rebuild for OE P8
    send for repair to gems
  39. #37
    Mar 2003
    West Sussex
    GEMs repaired it and converted it back to 4 injector. So all good!
  40. #38
    Jun 2012
    Slovakia
    where was problem?
  41. #39
    Aug 2018
    Greece
    31
    Hello to all! I saw your conversation here and should like to ask you midnightman if you could also decode me a p8 pectel board chip in order to copy the maps and run that to an other p8 without board? Thanks!!!
  42. #40
    Dec 2015
    Denmark
    Hi
    Send a copy of the Pectel Eprom.
    I will decode the Map-part and send it back.
    Regards
    Kim Bonde
