ST170 sump
Can the St170 sump be cut and welded to suit rwd like you see some lads have done
I don't want a steel cvh one but cant find a 1.8. Zetec alloy sump
Re: ST170 sump
Is the ST sump a two parter - alloy against crankcase and tin under? If so its unlikely as the Mondeo one I tried with is angled in two directions and by the time it was milled flat most of the windage tray / bracing was gone and was getting a bit close to the seals. Never say never but not easy if paying someone IMO.
Re: ST170 sump
This is it
I would be making it myself.
Re: ST170 sump
it can be made rwd - see my westfield thread - but you wont get it around an escort xmember, just flat for kit cars.
Re: ST170 sump
Thanks ya I'll be fitting it to an escort.
I tried to find your build but cant, have you a link
ST170 sump
Should be under my name if viewing on A pc
Or search words.
hole in head
