Results 1 to 7 of 7
Thread: 3 wire speed sensor questions? Electronic speedometer.
    Mar 2013
    Worcestershire
    155
    20
    I am planning on running a VDO electronic speedo on my RS2 rebuild. I have purchased a 3 wire speed sensor and adaptor to drive directly off the type e gearbox.
    Sensor wiring is +ve, -negative and signal / pick up.
    The VDO speedo has a terminal for sender signal +ve and sender signal -ve
    Has anyone got any experience with this kind of stuff that can advise which 2 wires from the sensor I connect to the speedo?
    Cheers,
    Dave.
    Re: 3 wire speed sensor questions? Electronic speedometer.
    doubt you can, two wired speedo means it wants analog AC signal from a magnetic pickup, the 3 wire speed sensor is a digital hall effect
    Mar 2013
    Worcestershire
    155
    20
    Thanks for the reply Graham, thing is VDO state it can be used with a hall effect or inductive pick up. The even sell the 3 wire hall effect sensors but they are all to suit US vehicle fitments. I have emailed VDO direct to ask the question.
    in that case i would expect to connect to the + and signal connections, as i would expect the signal to be a switched earth
  5. The Following User Says Thank You to Graham For This Useful Post:
  6. #5
    Mar 2013
    Worcestershire
    155
    20
    Then just earth the other wire for the sender? I assume it will still need that?
  7. #6
    Quote Originally Posted by gpw1945 View Post
    yes the sensor needs the earth to operate. you will also need a 12v supply to the sensor +
  8. The Following User Says Thank You to Graham For This Useful Post:
  9. #7
    Mar 2013
    Worcestershire
    155
    20
    Thanks, I'll rig it up on the bench first with drill to drive it and see what it does.
