Its a good enough solid shell also got an rs2k
Im hoping the engine and box will fit , anyone done this ? its only 2wd
Good luck with the project
no but i imagine it wont be strait foreward the early car has got a gearbox crosmember and the later car has a front subframe
just in case you are wondering matey, those rs2k wheels look the shizzle on the mk4's
A lot of things have changed...........but turbosport isnt one of them
Originally Posted by andy
Yeah hoping to get them refurbed and also fit the recaros ect , got the rs for £200
The rust is so bad on it the door falls to the ground when i open it the piller is fooked , the rear spoiler lifted off and there is a 3 inch hole in the middle of the tailgate , but the engine had a recent overhaul so it runs very well .
the recaros may be a bit of a scutter to fit as they have different subframes i believe, but im sure you will find a way around it
are u fitting the rs2000 engine in the mk4 m8
Yes hope so , made a start last week going to trial fit it tomorow and will get some pics once its in .
Keep us updated on this as it will be interesting to see how it goes!
they only just go in m8 a friend of mine as got 1 an very fast the only thing is u mite fave to get a frst box 4 it m8 as the 2000 1 mite not go in an bolt up
Ive seen the mtx75 box in s2 tubos so im sure the engine and box will go in but im not sure if the shafts will fit .
not sure on the box mate although i would say yes it will.
i fitted a zetec to me 3door mk4 bonus shell and its sweet!!! with the RS2k I4 powerplant ul having lots of fun, although traction could be an issue!!!!
it is with me 1800!!!
Sideways is the best way.
I got started taking mk4 apart , and fit stealths
engine will be out next week then ill start welding
Hope to use the clocks in the mk4 and my trusty old momo thats been in most of my cars
is it a 4speed box with the bonus mate??
U have been busy m8.
chiz did you use the zetec box on yours or did you swap the flywheel & put a mk4 on it ? as i know the mk5 will fit the mk3 but not sure if it fitted the mk4 as it will save me messing about
i just used the zetec clutch and bolted up the 4speed from the mk4 mate, fits no problem, although ur 2L flywheel n clutch will be different me thinks..... so ul need a cvh fly n clutch maybe?? or 1800 zetec fly/clutch??Originally Posted by paulw
does that help mate??
