Raised boot floor questions
Hi I have a raised boot floor with swirl pot cut out from grp4 fab
http://grp4fabrications.com/product_...roducts_id=218
im trying to work out a few things
if I'm running a fuel tank on a platform with a built in swirl pot do I still need the cut out and if so does anyone have a picture of how it looks as I haven't got the tank or platform yet!
and also the watts linkage sits on the boot floor that you cut away are there different boxes or do you just fab some metal in to link to the new floor?
thanks
Re: Raised boot floor questions
Any help? Boot floor on mine has been raised 2".
there is alot more fab work done on that mk2 shell than raising the boot floor the whole rear chassis was raised and a new chassis crosmember fabbed to make watts link towers.well over 30hrs work in that section alone.
Was going to point him in your direction if that's what he was on about.
thanks lee but i think there are plenty of really good fabricators much closer to him than coming all the way over to me the travel costs alone would nearly be more than the labour .
thanks for the replies, ive ordered the tank platform so I will work it our when it arrives! but speaking to grp4 the raised floor is available in two parts a complete raised floor then a higher piece just to cover the pigs head area I only need a special tank etc if using both pieces which I am not so I should be fine
