Results 1 to 12 of 12
Thread: Escort mk1 Hilux Axle LSD
    Aug 2015
    malta
    31
    Hi guys,
    can anybody help me with finding out which lsd is good for this type of diff? I contacted quaife and the guy told me that its the same diff as the gt86...are there any other suppliers out there for lsd clutch type diff or quaife is the only company?
    regards
    christian
    Mechanic v8ian's Avatar
    Dec 2004
    FarFar south, any more and my feet are wet, sunny sussex
    728
    Re: Escort mk1 Hilux Axle LSD
    When i ran a celica lsd which was basically the same as a the corolla axle, I was told the Lsd from a straight 6 celica supra it was the same even though it was an irs, I never broke my led to need spares.
    Bodger RS Eskie's Avatar
    Feb 2008
    New Zealand
    132
    23
    Hey schranz, I have a hilux rear in my RS and they are an 8inch head,I thought the AE86 were 7"? if you can get hold of a later model hilux lsd as they have a better clutch pack apparently and get it shimmed it should suffice. I bought a 4.1 and tried hunting for a 3.7 which are hard to find here and a diff specialist happened to have a supra 3.7,not sure what year supra sorry and they put it in and shimmed up, happy days!
    Mechanic Matt75's Avatar
    Mar 2011
    Melbourne
    604
    23
    Kaaz make the LSD units to suit these
    Matt
    May 2007
    cardiff
    Quote Originally Posted by schranz View Post
    Hi guys,
    regards
    christian
    Hi Christian can you private message me regards will cardiff
    Aug 2015
    malta
    31
    hi thanks for your comments, i can fetch you a 3.7 diff here easyilyy Rs eskie. if you want let me know il help you out
    thanks
    chris
    Pit Crew MK1_Oz's Avatar
    Nov 2008
    Adelaide, Australia
    1,287
    79
    I use a Kazz in my tarmac rally car Hilux - SAT 3030 IIRC
    Dec 2013
    kent
    47
    80
    14
    thanks
    chris
    What vehicle and year are the 3.7 diff ratio fitted to ??
    Dec 2013
    kent
    47
    80
    14
    The Kaaz SAT 3030 lists that it requires a spacer for the crown wheel is this all model hilux or upto a certain year ?
    Mar 2011
    Melbourne
    604
    23
    YOu can also use a Torsen type LSD from a supra / cressida too that bolts in with no mods. Not sure on benefits / problems with this style of diff though
    Matt
  11. The Following User Says Thank You to Matt75 For This Useful Post:
  12. #11
    Nov 2008
    Adelaide, Australia
    1,287
    79
    Quote Originally Posted by goldy View Post
    Recently took mine apart and cannot remember if there is a spacer in there. If there was it is very thin. 95% sure the crown wheel was bolted direct to the Kaaz
  13. The Following User Says Thank You to MK1_Oz For This Useful Post:
  14. #12
    Jul 2009
    Perth, Australia
    111
    The spacer is required for all years. Yes it is thin
  15. The Following User Says Thank You to Virgil For This Useful Post:
