Re: And now for something completely different, Rover Sd1 Stage rally car
Well guys, been beavering away, and getting somewhere...not very fast.
Firstly, got the rear turrets finished off...............
Then moved on to the linking arrangement for the axle, please bear in mind that this is mostly guess work, I was hoping to go have a look at a proper car that has the 4HA under it, but had some idea so just freestyled it.............
Holes for link boxes.......
Link boxes made.......
Now then, for the link bars to fit, they fit to the piece of the shell tghat is upright where the back seat usually is, this is fairly thin steel, so I have plated it with 2mm steel, and tied it to the shell by removing the embossed parts and welding through, i'll let the pics do the talking........
Then welded some link bar brackets I made........
Then I had to remove some of the boot floor to accomodate the watts linkage.........
Then filled it in...........
(Thats finished off now by the way)
Then started on the watts towers......
Since then I have strengthened all the towers, fully welded everything, drilled etc. next on the agenda is dipping and painting...........watch this space.
