Results 1 to 13 of 13
Thread: Engine that can't.
    Sep 2003
    Barbados
    1,284
    19
    Engine that can't.
    Just using what I have at the moment..but have two options.
    Because of class rules, I can use programmable ecu but must retain stock intake and throttle body. Or I can use side draft webers and any ignition system.
    Can decide which would be better.
    Suggestions??
    Thanks.
    1973 mk1 escort
    1982 Toyota corolla ke70
    1988 mk4 escort
    25,132
    313
    Re: Engine that can't.
    if your looking for maximum power then surely sidedrafts and a mapped ignition system is the way to go
  3. The Following User Says Thank You to Graham For This Useful Post:
    3,248
    Agreed - stock intake will have no performance enhancements so a aftermarket ECU, no matter how clever, will be wasted.
    Carbs and mappable ignition may take more time setting up but will be streets ahead in power department!
  5. The Following User Says Thank You to katana For This Useful Post:
  6. #4
    4,904
    If you are stuck with stock cams (does anyone make fast road / rally cams for this engine?) then even with twin sidedrafts and mappable ignition bhp will not be high.
  7. #5
    25,132
    313
    cam lobes in these engines are massive so plenty of meat to reprofile if required, im assuming its the 8v version, 16v cams are avaiable for sure
  8. #6
    Sep 2003
    Barbados
    1,284
    19
    Yes its the 8v..internally only that must remain stock is the crank.
    1973 mk1 escort
    1988 mk4 escort
  9. #7
    25,132
    313
    i do recall for a short while these were used in a single seater, i think it was meant to be an updated FF2000, i think it died a death but i do recall reading about the cams having such big lobes that they could regrind them and get a lot more duration at the expense of only loosing a small amount of valve lift
  10. #8
    May 2004
    Norn Iron
    1,148
    Doesnt look like an awful lot of room there for sidedraughts ? They'd be slammed right against that inner guard ?
    9.85 @ 145mph 202mph standing mile
    https://www.youtube.com/watch?v=Ss_c7fML3rw
  11. #9
    Sep 2003
    Barbados
    1,284
    19
    Used to have webers and cvh distributor then move to 1.8cvh ignition.
    1973 mk1 escort
    1988 mk4 escort
  12. #10
    Sep 2003
    Barbados
    1,284
    19
    That's where I'm at now, the stock engine setup worked surprisingly well last meeting. Now I'm looking at regrinding some cams..any info or opinions on cam grinds??
    1973 mk1 escort
    1988 mk4 escort
  13. #11
    Sep 2003
    Barbados
    1,284
    19
    Looking at the inlet port here, should i 'straighten' the port or just work the guide boss and keep the cross section to minimum???
    Below is an inlet i did on a head many years ago just exploring boundaries of the was but i never used it.
    Opinions....thanks.
    1973 mk1 escort
    1988 mk4 escort
  14. #12
    Sep 2003
    Barbados
    1,284
    19
    Valve sizes are 43 and 38mm stock.
    1973 mk1 escort
    1988 mk4 escort
  15. #13
    25,132
    313
    straightening the inlet should be good, ive never done any performance work on one of these, let alone stick one on a flowbench, but it looks to me like your eairler but un tried attempt should work
  16. The Following User Says Thank You to Graham For This Useful Post:
