    • 25256
    my race car, the worlds most powerfull 316- probably?
    although we have been talking about my car in another forum i thought it time i put it here seeing as it is a competition car
    Body
    1988 E30 2 door 316
    Custom Cages weld in multipoint cage
    fibreglass bonnet, radically lightened doors
    polycarbonate windows all round
    engine
    E30 m3 S14 16v evo2 (215 bhp std)
    fitted with E30 s14 evo3 87mm stroker crank
    94mm 2.8 v6 turbo accralite pistons on m10 conrods
    2415cc
    7.7:cr
    .5mm overize race exhaust valves
    48mm throttle bodies
    retimed std cams
    very light steel flywheel
    hybrid turbo technics T38 turbo
    home made exhaust manifold and 3 inch exhaust system
    homemade inlet plenum
    sierra RS500 race intercooler
    electric waterpump
    Anglia radiators hybrid radiator
    grey Yb cossy injectors (way too small bigger ones on way)
    Emerald M3DK ecu
    transmission
    7.25 twin plate sintered AP paddle clutch
    E30 M3 gearbox and prop
    E30 325 3.46 LSD
    Brakes
    EBC yellow pads
    motul race fluid
    mk2 escort bias pedal box
    front brakes willwood superlite 4 pots and 300mm discs
    rear brakes std E30 325 discs minus back plates, handbrake totally removed- rear brakes due to be further to be uprated
    shocks
    Leda Adustable ride height and damping coil overs all round, rears rose jointed
    rear suspension,
    poly bushes, E30 m3 rear roll bar, bmw Zm3 coupe diff mount, upsidedown axle mount bushes
    front suspension
    E30 325 touring aluminium wishbones
    318is PAS rack with power steering removed
    rubber coupling removed from steering shaft
    rose jointed track rod ends
    quick release steering wheel
    poly bushes
    redrilled TAS universal top mounts
    3 position adjustable anti roll bar
    wheels and tyres
    compomotive 8x15 200/580/15 slick front
    compomotive 9x17 235/610/17 slick rear
    at the time of posting waiting for new bigger injectors so more power to come
    but at the moment 404bhp, 405lbft @5700rpm using 12psi boost
  • mk1 gaz
    Spam Man
    • Jun 2005
    • 5408
    bad to the bone
    • luz008
      • 1602
      very nice
      • PIG
        • Oct 2004
        • 11882
        oh i like that
        • Dave
          • 19588
          Apologies if you have already said,
          what series are you racing in, where and when?
          Would like to come and watch sometime.
          Belting car.
            • 25256
            it will be out in the Dunlop track and race car championship, the championship caters for every thing from fiesta's and X/flow powered mk1 escorts AKA Andy Pipe to fire breathing monsters, like Rod Birleys 541bhp WRC Escort and John Cross's V8 Eurocar engined Focus
              Graham, is the rear bumper getting painted or are you waiting to see if a certain VW is signed up again
              Its gonna be fun out there this year..
              • Dave
                • 19588
                Bugger! all down south again.
                I'll probably make one of them though.
                  Thats looking very handsome Mr Bahr. Wish we'd made it to the rollers now to see it.
                  I'm sure thats gonna suprise quite a few people this year.
                  Did you run without the pas last year, and is that a quick rack??
                  • markb
                    • Feb 2003
                    • 6821
                    very nice indeed. I'm looking forward to seeing this go!
                      Looking good Graham cant wait to see it on the track this year
                        • 25256
                        dont look too close at the paintwork diabolical would be too kind a word for but but its ok from a distance.
                        yes i ran without pas last year, car was non power in the first place, so a power rack is a bit quicker, but without the hydralics isn't heavy.
                        in my opinion and experience you dont really need a quick rack on a tarmac race car as long as you can get it to turn in properly, on slicks on tarmac is if you cant recover a slide with half turn of lock or less you not going to ,quick rack or not!
                        thats not to say they dont have there place they do particulary on the loose, i guess it also has to be born in mind most beemers arn't as tail happy as escorts
                          • 25256
                          its staying black, bring on mr inskip and let him try to get close enough to try those tricks again
                          that said theres a chap on another certain forum who has posted in black and white how he's going to blow me away on the straights in a fiesta!
                          ok its turbo'd but he thinks 250bhp is fast but he really believes hes gonna out drag me!
                          bring emm on i say, last year i set out to prove a concept, this year i mean business, which probably means i'm gonna spend half the season in a gravel trap or the percy: percy: percy:
                            That, Sir, is the Pre-Season quote of the year
                              • 25256
                              rolling road update,
                              to recap, last time we ran it the engine went danerously lean at high revs so we had to abort, so we rebooked the rollers and ordered some bigger injectors
                              went back to the rollers today but unfortunatly the injectors are somewhere over the Atlantic at the moment, so we had to be content with trying to back the boost off enough to get the mixture safe enough to race on, it sort of worked, the lowest we could get is 8psi and its still going lean at just over 6000 but its safe enough to race on if i keep the revs down
                              knocking the boost back has dropped peak torque to 350lbft, but as i can rev it on further than before peak power is 425bhp, which should be more than enough for this coming weekends shake down, and even then wway to much if the rain thats forecast happens
