I have read all the posts on axle triangulation kits and I can honestly say that I was shocked at the improvement it made to the rear of my Capri.
I poly bushed my car to start with, and as expected this tightened things up a bit, less figity on uneven surfaces, but giving more noise over smoother surfaces.
I then fitted a pair of Monroe gas shocks (fixed damping), these improved things a bit more, less body roll at low speed and better traction. But this could have been down to shagged shocks in the first place.
I then Fitted a triangulation kit and this made the single biggest difference to the way the car handled,the back end now felt like it was conected to the front end of the car. Axle tramp was now not even a factor and the extra control at higher speed when cornering was very reasuring. Body roll was improved dramatically as so was side to side movement of the axle.
The kit I used actually clamps around the axle casing and the has a flat link from the top of this clamp, the flat link then conects to the front portion of the spring. this in itself helps stop axle wind up and puts the sideways forces from the axle nearer the front spring mounts keeping sideways movement to a minimum, any movement in this setup will come from the bush itself.
I feel that to go beyond what this set up is capable of, you really need to wonder what people are doing with there cars. What I'm getting at is, if you are cornering with such force on the public road that the axle still wants to vacate the rear arches. Then your probably not driving anything that ressembles an old rear wheel drive Ford ... Let alone a Capri!
(I mean in terms of normal levels of "fast road tune" before I upset anyone)
So in summary, if you are driving something thats sporting 300 Bhp plus and doing regular track days and maybe motorsports, then maybe you need to look elseware, but for probably 90% of us classic rear drive fans this sort of set up is very relevent.
